Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 05-21-2020, 04:04 PM
blindsidejamie blindsidejamie is offline
Default Benefits of interface for can-centric workflow
hi all
I'm running native PT Ultimate just out of the MBP headphone jack. I only do post editorial at home. Dial, foley, and some FX editing -- simple sessions.
I'm curious if there is a big incentive to invest in a Thunderbolt/USB interface if it's a modest system for occasional (that can expand?) work? Better headphone output level? Huge quality difference? I have Beyerdynamics 770 PRO 250 ohm cans.
Thanks for your input
MacBook Pro Retina Mid 2012
2.3 GHz Intel Quad Core i7
8 GB 1600 MHz DDR3 RAM
Mac OS 10.14 Mojave
Pro Tools Ultimate 19.5.0
Old 05-21-2020, 09:37 PM
smurfyou smurfyou is offline
Default Re: Benefits of interface for can-centric workflow
I also do post editorial at home with DT770’s. I’m surprised you’re driving them with the built-in output. With an internal sound card I had to use “normal” impedance cans And I hear noise and interference with both Mac and PC laptops.
So I always use an interface. I have the usual rack mount interface at home but I have a couple of tiny USB boxes that I use for travel or when I need an extra seat. Used to use the Mbox mini but drivers were terrible. Nowadays anything from Presonus and Focusrite is good enough. Steinberg, Roland, Tascam. Honestly they all use similar quality components and they’re cheap as chips when you’re making a living using them. The quality difference is worth it for me. Spending more will get you more features and I/O but not necessarily a better headphone amp. Stepping up to an RME Babyface would be an improvement but only worth it if you need the extras.
~Will
Benefits of Avid Native Thunderbolt over a USB interface? V5V Post - Surround - Video 12 10-07-2018 12:34 AM
New Waves Greg Wells Tone Centric is a very good example for the CPU Peaks/Errors Franklyn Pro Tools 12 14 10-26-2016 10:21 AM
Workflow: Creating Film score music (template/setup/workflow) jhonny.eriksson Tips & Tricks 5 03-03-2015 10:08 AM
Audio-centric - best way to add slides to audio? revans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-02-2010 05:47 AM
PRE getting knocked offline by MIDI-centric editing, 7.4.2 SmokinBaldMonkey Pro Tools TDM Systems (Mac) 0 06-24-2008 09:53 PM
