Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 03-04-2020, 07:41 AM
madselhoff madselhoff is offline
Default breakout cable for Mbox Pro?
Hi! I still do love this unit (3rd gen.) so I just purchased it used for 60 bucks and it works perfectly!! The only thing missing is the breakout cable so I can connect spdif. I've searched the webs for this 15 DP connecter, but no luck this far. Does anyone know of a solution like maybe a third part solution or something (m - audio etc) ?
thank you in advance :)
... mads
Old 03-04-2020, 09:10 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: breakout cable for Mbox Pro?
If you cannot find a ready-made cable, do it yourself.
It is a standard 15-pin VGA connector that is used for MIDI in/out, clock in/out, and SPIDIF in/out. Knowing that SPDIF is unbalanced you probably only need to find one of the pins (hot) to connect once you have your ground (cold) soldered. Doesn't take so long to find out once you are on it. Little harder if you need to find two pins out of 15. In that case Avid Support may provide you information about which pins to connect. Not sure about that but worth asking anyway.
Janne
Old 03-04-2020, 07:10 PM
You should also check eBay as they show up from time to time. And check with an Avid-authorized service house like allproelectronics.com(based in Nashville)
MBox Pro 3 Breakout Cable geraldinedodo FireWire & USB Audio Interfaces (Mac) 2 12-31-2017 11:28 AM
Missing breakout cable for Mbox Pro 3. How to connect SPDIF out from Mbox Pro 3? Focuret FireWire & USB Audio Interfaces (Mac) 2 12-08-2016 04:02 PM
Breakout cable for Avid Mbox Pro 3 Aclc FireWire & USB Audio Interfaces (Win) 5 01-25-2016 05:51 AM
Mbox 3 Pro Breakout Cable Fooks FireWire & USB Audio Interfaces (Mac) 1 08-30-2014 01:49 PM
Mbox Pro 3 Breakout Cable nhmorgan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-09-2013 11:33 AM
