Old 07-14-2014, 02:52 AM
markallen5 markallen5 is offline
Default Is There A way to use S.Gear/Scuffham amp with M powered 7.1 delta 1010LT card ?
Hello from probably the most incompetent pro tools user ever,
I really would like to use SGear's scuffham amps amp plug in, but they told me it doesn't come in a compatible format for my aged pro tools 7.1 M-Powered using a delta 1010LT soundcard. I use a Dell inspiron still using windows XP. The pc I use isn't connected to the internet.
Can you help ?
Mark.
Old 07-16-2014, 06:36 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Is There A way to use S.Gear/Scuffham amp with M powered 7.1 delta 1010LT card ?
If you want to use that plugin with Pro Tools, then you will have to upgrade to PT 10 at least, or use a VST wrapper.
Here's the requirement from S-Gear's site:
Plug-in formats (PC):
- VST2.4, AAX (32 and 64bit)
Your old Pro Tools uses RTAS plugins, not AAX (which PT 10+ supports).
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 07-18-2014, 01:02 AM
Hi Joel,
Thank you very much for your advice. I will look into the VST wrapper thing.
Regards, Mark.
Scuffham Amps S-Gear Rosco1969 AAX Plug-ins 8 03-09-2014 11:40 PM
Pro Tools M-Powered Essential 8 + Delta 1010LT davebelling Pro Tools M-Powered (Win) 0 02-06-2012 04:00 PM
PT and Delta 1010LT ziggy1621 Pro Tools M-Powered (Win) 0 01-03-2008 06:26 PM
M-Powered 7.1 + Delta 1010lt: optimizing performance? Berrado Pro Tools M-Powered (Mac) 1 03-14-2007 06:17 PM
Multiple Delta 1010LT Cards and M-Powered 7.3 cwsand Pro Tools M-Powered (Win) 2 01-05-2007 10:37 PM
