Old 09-09-2011, 02:59 PM
Drummersound Drummersound is offline
Exclamation Help with System Usage Window!!
Hello everybody!
I'd like to know a few thinks about this window because the info in reference guide is not the best...
Can someone tell me what does it mean:
Time Slots Used
Plug-in Sharing
DSP sharing
StereoMixer24
WaveShell-DAE
So, how can I explain those thinks in a easy way to someone?
Thanks a lot!!
Old 09-09-2011, 06:04 PM
Hanswurstlsepp Hanswurstlsepp is offline
Default Re: Help with System Usage Window!!
Originally Posted by Drummersound View Post
Hello everybody!
Time Slots Used
Plug-in Sharing
DSP sharing
StereoMixer24
WaveShell-DAE
Thanks a lot!!
I will try:
Time Slots Used
For every PlugIn you instanciate or adding outputs or make other kinds of routings within the TDM mixer you need a certain amount of TDM Time slots.
If I recall correct, the maximum amount is 512 using 44,1 kHz. It's getting less the higher the sampling frequency will get.
Plug-in Sharing
PlugIns & Mixer can share one or more DSPs.
DSP sharing
DSPs can be shared by TDM-PlugIns and the Mixer-PlugIn itself.
StereoMixer24
There are different Mixer-types available within PT. Like a stereo mixer and a surround mixer, dithered or not, 16 bit or 24 or higher. They reside in PT's PlugIns folder. Depending on the settings of a session, they might change.
The surround mixer for example is also needed if you want to change the pan law to something higher (wider) than -2.5 dB.
The "more" mixer, the more dsp usage
WaveShell-DAE
WaveShell (DAE) is a global plugin from Waves which is instanciated as soon as you use a Wave's PlugIn. The more Waves TDM - plugins you use, the bigger the waveshell-PlugIn will become and the more DSPs it will eat up.
... writing this while laying on sofa .... so it's just a quick recall what I have in mind. So please, someone else might feel free, to correct me
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 09-12-2011, 08:23 AM
Thanks Hanswurstlsepp!!
I have one more questions:
When I open a blank session without tracks,
Why do I see that there is 2 voices in use on "Voices allocated"?
What consume those voices?
Thanks again!
Old 09-12-2011, 08:44 AM
crizdee's Avatar
crizdee crizdee is offline
Thanks again!
The stereo master output, although its not showing all sessions have one by default.
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-12-2011, 08:48 AM
Thanks a lot crizdee!
System Usage Window not as described dts350z Pro Tools 10 1 11-09-2011 05:07 PM
System Usage Window zlr77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-09-2011 09:54 AM
System Usage window. maccool Tips & Tricks 2 04-16-2005 01:37 PM
system bar in sys usage window hobo123455 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-01-2004 02:21 PM
system usage window?? carbomb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-03-2002 07:54 AM
