Old 07-26-2010, 04:19 AM
rolling_beat rolling_beat is offline
Default PT 8 files issue
Hi everyone,
i've just finally upgraded a pair of pro tools to 8!
I'm running a PT8 cs3 on a Mac Pro.
I've just discovered that PT modifies the "modification date" on the audio files of the session you're running.
In PT7 this would never happen, except if you modify the audiofiles in some destrictive way.
Now it's happening all the time i even open a session....
This is not big deal, but does anyone knows why do this happen and if it's possible to control it (maybe for backup purposes) ?
thank you!!!
Old 07-26-2010, 09:14 AM
Craig F Craig F is offline
Default Re: PT 8 files issue
the files are being updated to 16 bit overviews (was 8 bit before) this is for the long requested ability to see the grid lines through and the peak/power view option
yea, it make for apain at the start but it's a good thing down the road
Thank you,
Craig
Old 07-26-2010, 09:17 AM
DigiTechSupt's Avatar
It's updating the modified date because Pro Tools 8 supports 16 bit waveform overviews and updates them in each of the audio files.
This is documented in the Pro Tools 8 Read Me.
Avid Audio Tech Support
Support FAQ
Old 07-27-2010, 12:58 AM
thank you guys...
so if i'm understanding it the right way:
the "modification date" is modified only in sessions coming from PT7...
it shouldn't happen on new sessions created on PT8 right ?
Old 07-27-2010, 09:14 AM
Originally Posted by rolling_beat View Post
thank you guys...
That's correct - as long as those sessions are not importing audio that was created in Pro Tools 7. If you import audio that does not have the updated 16 bit waveform, Pro Tools is going to modify the file.
Support FAQ
Old 07-28-2010, 12:30 AM
got it!
thank you!
Issue with lots of files. Frank Kruse Aspera DigiDelivery 0 02-06-2012 06:58 AM
Issue with Karaoke MP3 files Fuzzyc Pro Tools M-Powered (Win) 2 04-23-2011 08:09 AM
Version issue of session files between 6.4 and 7.4 mizo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 01-12-2008 01:51 PM
7.4 issue with missing XP files paul m 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-02-2008 06:05 AM
Digizine Issue, deleted session files tbonechillaxin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-01-2006 08:49 PM
