Old 08-24-2008, 11:44 AM
crizdee's Avatar
crizdee crizdee is offline
Default Getting parts for control 24? need rotary encoder pots replacing!
Several of the most commonly used rotary encoder pots the first 3-4 on the left, on my Control 24 have worn-out and are no longer functioning correctly, so i was wondering if they are available anywhere and whether they are easy enough to fit.
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-27-2008, 12:52 PM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
Default Re: Getting parts for control 24? need rotary encoder pots replacing!
I'd open it up and get the manufacturer number off them, and order a ton of them online. Bet you can get them out of China for $1.00 or $2.00 each TOPS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I've found this to be the case with MANY electronics - including touch screens for Triton's (Origional Triton Keyboard touchscreen through Korg was $450, got it from the manufacturer for $150)
You may likely have to un-solder one to get numbers, depending on where they're stamped.
If you can't get them from Digi, this may be your only option.
If you do have to order some, and find them in China or wherever, let me know and I'll buy a bunch with ya.
If I'm in mine anytime soon I'll look you up here and tell you what they are (If I don't have to remove one to find out)
Also, if you get the number and shoot me a picture of all sides I will help you locate.
Simple Simple.
Even then, if the origional isn't available, there will be a cheap replacement.
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Old 08-28-2008, 04:47 PM
Scott Goldberg Scott Goldberg is offline
Chris,
Is any of that helping? I have a couple of other connections we haven't explored yet.
Squatty
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
2.6.1 Rotary Encoder Issues, and MC Control Touch Screen Freeze anotherchrisperry Artist Series 12 05-04-2012 01:45 AM
Using keyboard rotary pots as a MIDI control surface for plug-ins AndyMVP MIDI 3 05-19-2011 09:55 PM
Rotary encoder resolution mixboy bob ICON & C|24 2 11-18-2008 03:43 PM
rotary encoder not working tomcat ICON & C|24 2 01-07-2007 02:14 PM
dead rotary encoder. any tips on replacing? tomcat ProControl, Control|24, Command|8 1 08-06-2003 05:30 AM
