Old 06-21-2008, 04:49 PM
hkbluesrider hkbluesrider is offline
Default Mbox With MacBook 2.16 Optimal Set-up for max Performance
I am wondering what the best setup for attaining max performance out of my set-up is. I am running the following below. I have read other post that state they are running tons of plug-ins and I have hardware crashes with just 4 plug-ins. Please give advice!!
PT 7.4
Macbook 2.16 2 gig ram
original Mbox
Thanks for any help!!
Justin
Old 06-21-2008, 05:30 PM
Sounds Expensive's Avatar
Sounds Expensive Sounds Expensive is offline
Default Re: Mbox With MacBook 2.16 Optimal Set-up for max Performanc
I can relate.
PT just isn't as powerful as it was when I owned my 1st Gen. Macbook: 1.83 GHz and 1 Gig of RAM, with Tiger and PT 7.3.
I used to be able to really push that machine to it's limits (32 tracks, 10 - 12 FX returns, Master track, and plugins on everything and everywhere!!) and it would still function, albeit a little slower.
Now, I'm lucky if I can get 1/2 that. And, everything is up to spec. and date according to Digi's guidelines. I'm bummed!
Current set-up:
Macbook: 2.1 Ghz Intel Core 2 Duo, 2 Gig of RAM with Leopard 10.5.3
Digi 002r, PT 7.4.2
www.propellersound.ca
Which MacPro For Optimal Pro Tool Performance rogercollege macOS 12 04-25-2012 03:36 PM
Optimal performance settings on satellite Nathan W. Post - Surround - Video 3 12-30-2009 08:55 PM
Is there a max partition size for optimal performance? mtung Pro Tools TDM Systems (Mac) 2 04-13-2009 12:46 PM
Optimal Performance with 7.4.2 on New(er) Mac Pro Dowski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-30-2008 08:59 AM
Will I get optimal performance from 001 with this G4 system? mikerica101996 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 10-19-2000 07:56 PM
