Running Out of CPU Power Error Message
I have just installed Pro Tools 7.3 on a new Mac Book Pro. I have only recorded one track so far and already I am getting an error. When I open a recent session and hit spacebar to play the track, the error message "You are running out of CPU power. Remove some RTAS plug-ins or increase CPU power usage Limit in the Playback Engine dialog (-9128)" comes up. Why? What does this mean? My Playback Engine Preferences are: H/W Buffer Size = 512 Samples RTAS Processors = 2 Processors CPU Usage Limit = 90% DAE Playback Bufer is at Level 2. My Mac is running a 2.16 GHz Intel Core 2 Duo Processor with 2GB 667MHz DDR2 SDRAM All I really have installed on the comp is Office and Pro Tools and the Ignition Pack so I can't figure out what is causing the problem as I don't have any more plug-ins that comes with this intial pack. I still have 70Gb of space left on the Hardrive and I'm buying an external hardrive later this week. Why am I getting this error message and what can I do to correct things? If there is any other information I have left out let me know and I'll add to the list. Does anyone know what the go is? Thanks, Maars |
Re: Running Out of CPU Power Error Message
I had the same problem with my new MAC Pro. Have you tried to change the port where you have connected the DIGI?
http://duc.digidesign.com/showflat.p...11459401145571 |
I only have the one firewire port on my laptop so changing that is not an option...
Thanks tho... Any other Ideas? Is this error likely to cause any problems? |
Go to the top of the DUC and try the troubleshooting tips. If that doesn't work, post back.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Error message!! You are running out of CPU power. Remove some Native plug-ins... | Jmissy87 | Pro Tools 10 | 8 | 06-17-2013 06:51 PM |
You are running out of CPU Power! Error message (-9128), I have tried everything! | thatguy22 | Pro Tools M-Powered (Win) | 9 | 08-24-2011 01:42 AM |
You are running out of CPU Power! Error message (-9128), I have tried everything! | thatguy22 | Pro Tools M-Powered (Win) | 0 | 07-24-2011 11:14 PM |
Error message with PT8 M-power | Eggy | Pro Tools M-Powered (Mac) | 3 | 03-12-2011 12:52 PM |
Digi 002 " Running out of CPU" error message... | Billy57 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-15-2007 10:33 PM |
