Old 01-22-2007, 09:47 PM
wolfman_rob wolfman_rob is offline
Default What is your Favorite Preamp for Drum Overheads
What is your Favorite Preamp for Drum Overheads. was thinking about a Millenia but thought id ask first.
was also Curious about
Langevin DVC
Presonus ADL600
John Hardy
Neotek
Grace
Buzz Audio
Any Suggestins Would Be Great
Thanks,
Russell
Old 01-23-2007, 02:24 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: What is your Favorite Preamp for Drum Overheads
This one.....
http://cgi.ebay.co.uk/ws/eBayISAPI.d...7632&rd=1&rd=1
Producer, Engineer,
www.ukmastering.com
Old 01-23-2007, 07:17 AM
PMoshay PMoshay is offline
Pre-amping what? The mic's have the most crutial influence on the sound.
Maybe consider alternate mic choices as well.
Mic's make the biggest difference to me (just after the source itself)
consider a sm57 and sm58...... about the same cost, both unidirectional cardoid mics.......very different sounding.
Beyond that discussion, Tube mic pre's are very different than non-tube pre's...... that all depends on what you want to hear.
www.LiveFromDarylsHouse.com
Old 01-23-2007, 10:08 AM
well i was looking at some mics too. i was just curious what alot of you favored for a Preamp for Overheads while i am on a preamp buying spree
Old 01-23-2007, 10:19 AM
Giles Reaves Giles Reaves is offline
I think what PMoshay was pointing out (and what I am pointing out) is that most of the time I choose the preamp to go with the mic. Or put another way, I choose the mic first, then choose the best match from the available preamps.
My answer would be in the form of a question:
What type of preamp do you not already have (or not have enough of), and what type of mics do you typically like on drum overheads?
Giles Reaves
Somewhere Between Tennessee & Utah...
Old 01-24-2007, 01:39 AM
Oli P Oli P is offline
A pair of KM84's with one of these Vintech pre's
The DPA 4006 is great for spaced omni setup
www.olipoulsen.com
iMac27 i9 3.6 (late 2019) / 64 GB Ram / OS 10.15.7
Apollo 8 / PT Ultimate 2020.9.1
Old 01-24-2007, 07:58 AM
kittonian kittonian is offline
KM84s with the Chandler LTD-1 (x2)
Joshua Aaron
President/Chief Eng.
AudioLot/AudioLot Studios
Pro Audio Sales/Consulting
http://www.audiolot.com
Follow AudioLot on Facebook
Old 01-24-2007, 08:28 AM
mixx mixx is offline
30 years of AKG 451's as standard ..Millennia pre's work well
ocassionally I have used 414eb's or U87's
Old 01-24-2007, 08:55 AM
trace1234 trace1234 is offline
You dont mention your budget... I am slightly limited and last year purchased a True System Precision 8 and have been very happy. It does not do a whole lot of coloration to your mic (which I like) so your mic will sound like your mic, which sends you right back to mic choice...I've used everything from Shure SM81's to Royer 122's and have been very happy with the results of each of those..Good luck and happy hunting....
Old 01-24-2007, 09:10 AM
tlester tlester is offline
The Precision 8's are decent middle of the line mic pre. Very little color, nice sounding. HOT AS HADES! You can fry and egg on on those, so make sure you have enough space in your rack to leave 1U above the unit open.
Tubes on overheads are often nice. Like a Summit 200B. I'll either go that route, or big iron, like a Neve (or Great River).
-Tom
http://SpeakRecords.COM
Drum Overheads What is your Favorite wolfman_rob Pro Tools TDM Systems (Mac) 4 02-26-2008 05:28 PM
OT M-S Drum Overheads flommer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-13-2006 07:33 AM
Drum Overheads skylab001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 04-25-2004 05:51 PM
What's your favorite mic pre for drum overheads? mikeoxbig Tips & Tricks 11 01-19-2004 01:53 PM
Drum overheads sound without overheads d_matt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-12-2003 06:57 AM
