Old 03-20-2006, 08:12 AM
cachemira
Guest
Posts: n/a
Default Digisnake ??
I´d like to buy an AES/EBU digital Digisnake to connect the XLR Male and XLR Females to analoge devices (such as an Eventide H3000 and a TL Audio Pa-1) and that way have 4 ins and 4 outs in a single DB25 conector.
http://secure.digidesign.com/index.c...&productid=686
Is that possible, or it only works in digital AES/EBU?
Regards
Old 03-20-2006, 08:29 AM
jeremyroberts jeremyroberts is offline
Default Re: Digisnake ??
Assuming you are using a 192 interface, that won't work...
Look at the possible connections of the 192, and you'll see that there is one DB25 for +4 analog ins, one DB25 for -10 analog ins, one DB25 for analog outs, one DB25 for AES/EBU, and one DB25 for TDIF.
Unless you wanted to do a custom build, you can't mix analog in/outs.
DigiSnakes are well built and are of high quality at a fair price. You can't go wrong with the digi branded product. There are other sources of wire too... some more expensive, some less.
--Jeremy
Old 03-20-2006, 08:34 AM
cachemira
Guest
Posts: n/a
I´m not going to connect the snake directly to a 192 I/O, I want to patch it to a DB25 patch.
I´ve got the 192 I/O connected to that patch too.
Old 03-22-2006, 09:10 AM
cachemira
Guest
Posts: n/a
Nobody knows?
I´ve asked a Digidesign´s dealer but had no reponse...
Old 03-22-2006, 10:29 AM
mattpete's Avatar
mattpete mattpete is offline
AES/EBU spec cable makes for a fine analog path. It will work in the application you described.
-Matt
Matt Peterson
Avid Audio
Old 03-22-2006, 11:38 AM
Craig F Craig F is offline
If I understand the question correctly you want to use the Digital ARS/EBU db25 to connect to analogue devices.
That will not work.
The analog inputs and outputs are on separate db25 connectors.
now if you have the AES I/O for your H3000 that would work.
Thank you,
Craig
Old 03-22-2006, 12:29 PM
RobMacki RobMacki is offline
Will this work for you?
You'd just have to adapt or replace the M/F ends as needed.
I knew that I had read that the analog snakes were also 110 ohm and were good for digital or analog signal.
I also think Markertek will custom make any configuration you need.
They might even have that in stock.
Digisnake 12' DB25 DIY theboasta General Discussion 1 10-14-2012 09:38 PM
Digisnake questions theaero Pro Tools TDM Systems (Mac) 6 08-27-2009 04:26 AM
digisnake for C24/002 combo JeorgeRec ICON & C|24 5 06-30-2007 03:08 PM
What is the best Digisnake for me? Stacyodell Pro Tools TDM Systems (Mac) 2 02-23-2006 03:26 AM
Which Digisnake cables usinare Pro Tools TDM Systems (Mac) 9 05-17-2002 11:45 AM
