Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 07-19-2021, 03:47 PM
ramonetl ramonetl is offline
Default Ferrofish Pulse 16 Interfaces Question.
Anyone using one of these? I have an Apollo 8p and I want to add one of these to hookup my external gear so I can keep all my external pres and stuff plus Kemper etc hooked into my setup without always having to unplug. Looks like nice units and adds 16 I\O though only 8 would go into my adat. But with sample rates, makes me wonder if I should get the mx for 150 more even though I dont use madi because you can upgrade it later if you want but it will cost you an extra 100. The plus is also you get the 192 if you want it out of the box though I usually do everything in 96. Thoughts? Peter
Old 07-20-2021, 12:37 AM
uptheoctave uptheoctave is offline
Default Re: Ferrofish Pulse 16 Interfaces Question.
I have the Pulse 16 DX CV and it is excellent.
Having Dante, MADI and ADAT onboard gives me much more flexibility.
I try to buy devices with as few limitations as possible, because I never know how I might want to work the future.
Old 07-21-2021, 08:46 AM
Thanks for the info. I decided against the MADI since I am a home studio and dont have long runs or the need for that. I can always add it if needed but glad you like yours. It arrives Monday I think. Appreciate the info. Peter
Old 02-08-2023, 10:56 PM
scremedy scremedy is offline
Hello. Tell me, can you get 8 ch of 96k per a single Adat port on the Ferro fish or only 4 per port? The back image description is a little confusing to me. My carbon will do 8 ch per port - with 4 total ADAT ports equaling 16ch I/O. The Ferro has 8 ports.
Thank for clearing this up.
Old 02-08-2023, 11:42 PM
A single ADAT/SMUX port can only provide 4 channels at 96 kHz. It has nothing to do with the implementation/vendor. You get 8 channels at 96 kHz with two ADAT/SMUX ports. You should read up on ADAT and SMUX specifications.
Old 02-09-2023, 07:18 AM
Thanks. Will do just that. - Scott
Old 12-29-2023, 01:37 AM
Kaianglow Kaianglow is offline
That's a good point.
Can I use a Ferrofish A16 (16-channel digital I/O) with a 192? firmflange Pro Tools HDX & HD Native Systems (Mac) 7 11-22-2017 09:23 PM
Constant pulse from plug-in. keelerstein macOS 4 05-17-2012 01:23 AM
Nomad Factory's PULSE-TEC EQs K.I. Pro Tools TDM Systems (Mac) 2 10-10-2009 11:32 AM
High pitched pulse SWW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 02-14-2007 08:26 AM
Pulse Window Disco_Doctor MIDI 1 02-06-2001 03:39 AM
