  #41
Old 07-10-2015, 01:42 PM
hjorte's Avatar
hjorte hjorte is offline
Default Re: How do you like to use HEAT?
Just for fun, here are 3 short samples from a recent 40-50 track mix I did. Surely, we could find better mixes to use for comparison, but this is what I've got at the moment.
The first one has HEAT turned off.
The second one has HEAT turned on and with the actual settings I used during the mix.
The third one I just dialed the Drive to the opposite position to hear how that sounds. I didn't mix into this setting.
I have adjusted the samples to have the same levels approximately. The mixes are not mastered nor limited.
I'm not sure if Soundcloud will deteriorate the audio, making the comparison less enjoyable or obvious, but that's what we got.
HEAT = OFF:
https://soundcloud.com/mrdudemachine/heat-off
HEAT = ON. Drive at 8 o'clock. Tone at 12 o'clock (off). This is the HEAT setting I used during mixing.
https://soundcloud.com/mrdudemachine/heat-on-d8oclock-t12oclock
HEAT = ON. Drive at 5 o'clock. Tone at 12 o'clock (off):
https://soundcloud.com/mrdudemachine/heat-on-d5oclock-t12oclock
  #42
Old 07-15-2015, 11:21 AM
noah330 noah330 is offline
Thanks for posting. I can hear a difference, no doubt!
  #43
Old 12-01-2019, 01:13 PM
Zarabozo's Avatar
Zarabozo Zarabozo is offline
Default Re: HEAT
Originally Posted by Drew Mazurek View Post
Upon playback, yes. But recording to a track with HEAT enabled doesn't record with the processing. HEAT is live in the mixer, either Pre or Post inserts.
I know this is a really old post and I don't know if things have changed.
I just tested this and HEAT *gets recorded* when printing a track. This is what I did:
1) All my drums microphones (audio tracks) end up in a stereo Aux track. So I created 2 audio tracks next to that Aux, with the same bus as the Aux as input, so I can print it twice.
2) I activated HEAT and went extreme (both knobs to the left) and started recording on the first new audio track.
3) I deactivated HEAT and started recording on the second new audio track.
With HEAT disabled, I listened to both tracks in solo mode, and the first one recorded the HEAT processing of the audio tracks from the drums. So now, if I enable HEAT again, this printed audio track gets HEAT again and it's like double processing.
So yes, if you want to print a track and don't want to double process HEAT, you need to bypass HEAT before printing. Or bypass it in the printed track.
The audio world is full of (mainly very expensive) placebos.
Windows 10 Pro 64 Bit
Pro Tools Ultimate (perpetual with active updates/support plan)
RME Fireface 802, Focusrite Clarett+ Octopre, Eleven Rack (ERXP)
Monitors: Yamaha MSP7 and Yamaha HS8S
Asus RoG Maximus Hero Z790 (in a 4U slidable rack mount! )
Intel Core i9-13900k 5.4 Ghz (16 cores / 32 threads)
128 GB RAM G.Skill DDR5 6000 MHz (4 modules 32GB each)
Boot disk: Samsung 980 Pro M.2 2TB
Media disks: 2 x Samsung 980 Pro M.2 2TB in RAID 0 for current work, 2 x Seagate Exos X20 20TB mirrored for archive and backup
Video: PNY/Nvidia RTX 3080 TI with a single 4K display Dell U3223QE 32''
  #44
Old 12-02-2019, 12:12 AM
Drew Mazurek's Avatar
Default Re: HEAT
Of course it does in the situation you describe.
I was talking about recording onto a track or tracks directly from inputs. HEAT is not recorded then.
www.drewmazurek.com
  #45
Old 12-02-2019, 08:27 AM
TOM@METRO's Avatar
Default Re: HEAT
Exactly.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
What is Heat? Soundtrack2life Pro Tools TDM Systems (Mac) 27 07-04-2011 08:40 PM
Can I use heat in PT HD 9 with a 003? evertonlouvize Pro Tools 9 11 01-21-2011 09:19 PM
Heat TDM only.... Camilo Orozco Pro Tools 9 0 11-06-2010 05:08 AM
PT 9 HD and Heat arnielarsen Pro Tools 9 1 11-05-2010 10:01 AM
