Transfuser Sync Issues
I've got a -
4 bar 1 bar 4 bar series of Transfuser patterns being triggered via notes, yet whatever Sync settings I choose I can't get the second 4 bar pattern to start at the beginning. Hopefully the picture will make more sense - the pink track is Transfuser having a 4 bar pattern being triggered at bar 6, yet it's starting in it's second bar...it's driving me nuts! |
Re: Transfuser Sync Issues
I feel you. I noticed last week that Transfuser doesn't seem to follow when you have patterns of different lengths. I was playing back my patterns while switching them live, and when choosing a 1 bar pattern preceding a 4 bar, the 4 bar picks up at bar 2. Not very 'drum machine' like behavior, though it could actually be useful in some cases(so long as you can decide when it happens).
The obvious work-around, is to string your patterns before you run your sequence. You can drag and drop your patterns right to the edit page in the order you want them. Thats what I ended up doing(and really works for me anyway, more 'mpc' like). Maybe not the way you want to do it, but at least you get your work done, the same end result. Till there's an actual fix(unless I'm missing something)... Hope it helps... |
I'm hoping Digitech will chime in here and say it's a known issue and is being worked on? |
Maybe you're doing more than I was? 'Cause I'm only using it for drums. But I was able to alter pitch, release times, and they were maintained in the transfer. Are you using a lot of automation within Transfuser? |
You can set the pitch, fiter, pan etc for each step of each lane in a pattern - this info is *not* copied over when you do drag'n'drop.
I'm severley p*ssed off atm - I thought AIR plugs were supposed to make the virtual instrument thing *easier* in Pro Tools yet here I am back to using GURU again as it just works and I've got a deadline to hit. |
That's funny. I like and am using Guru as well. Transfuser has it's issues to be sure. Could be a really great program though...
Good luck... |
I've submitted a technical support form about this issue.
I also mentioned that I've got hundreds of 24bit drum wav files which it won't import, even though I can import them into Pro Tools itself just fine. If anyone else is having the same problems, the link to submit a help request is - http://tinyurl.com/5gho4d |
Hi Remute,
please try this: set Sync in the sequencer to "16th" or "Off", then make sure that the subsequential notes do not overlapp or start/end in the exactly same position. If they do, remove a tiny little bit (1ms) from the end of the first note. Let me know if that helped. Thanks, Wolfram K Product Manager AIR Group |
Removing a tiny bit from the end of each trigger note, as suggested, does indeed "fix" the sync - is this the permanent solution or will it be fixed in a soon-to-be-released update?
Thanks. |
Unfortunately I spoke too soon. The problem is still there, as this picture shows - there's a 64th note space at the end of each trigger note, SYNC BEAT or OFF give the same result. http://img99.imageshack.us/img99/4117/picture3or6.jpg |
AIR Transfuser Synch Issues with Drag & Drop Loops into Pro Tools 9 | NAJM | macOS | 6 | 02-11-2011 04:03 PM |
Transfuser: My list of issues | Gothboy | Virtual Instruments | 0 | 10-03-2010 08:11 AM |
transfuser recording issues | kalony | Virtual Instruments | 0 | 07-27-2009 10:04 AM |
Transfuser Install Issues | djad05 | Virtual Instruments | 4 | 01-09-2009 03:29 PM |
Transfuser on the master fader with ADC enabled makes bpm effects out of sync. | Rubicon | Virtual Instruments | 6 | 09-25-2008 10:43 AM |
