Re: What's the difference between HD Native and HDX?
HDX only process AAX DSP plugins as I understand it.
So if I am running exclusively AAX Native plugs the HDX card does not improve performance by reducing the CPU usage of the 'plugin'. What about PT 11 'without' any Avid hardware and running core audio? What does the Avid native card do? does it only handle I/0? or does it also process 'native plugins'. Is there an Avid resource that would explained how this all works in detail? I don't want to buy a HD Native when I need and HDX. |
Garnoil,
If you are just running native plugins using HDX, it will be just your computer processing them. HDX will still take some load off the computer in that case, because I believe it handles the mixing as well, and obviously the tracking and I/O. But I'm not sure how tracking through plugins would work in that situation, because I thought I heard that HDX actually has slightly more latency tracking through native plugins than purely native systems. Maybe someone could elaborate on that. As for the HD Native card, I have learned a bit more since my previous posts in this thread (which were a while ago), since I now am actually using the system. Basically, there is very little processing on the native card. In practical terms, it may be more stable at very high track counts than typical consumer interfaces. Some people coming from older interfaces like the Mbox 2 or 002/003 have reported somewhat lower CPU usage running the exact same sessions. I compared it to a much newer interface, the Komplete Audio 6, and found no improvement that I could tell. This is not a negative thing, as both systems were very efficient. When it comes to latency, you will notice lower latency at any given buffer size vs. typical firewire/usb interfaces. This is from a combination of the efficiently designed Avid HD interfaces (which literally convert the analog to digital faster), and that fact that it's PCIe based, along with whatever little processing is done on the card. 64 is more like 32, 128 is more like 64, etc. Note that my experience even on usb/firewire interfaces has been very good in terms of latency. A 64 buffer on typical usb/firewire interfaces sounds like real time/no latency to me, whether singing or using amp sims, etc. So much so that I never bothered with 32 because 64 was perfect. With HD Native, that is improved even more. One other improvement in latency that seems to be unique to HD Native is the use of VI's. It seems much faster. Sometimes I'll be messing around with a VI and then realize I was on a buffer of 1024, thinking I was on more like 128 or 256. Previously, this would be very obvious, but not so much now. Keep in mind that VI's are only using D to A conversion, not the round trip of both A/D and D/A. And it may be that the D/A portion of the Avid interfaces is even faster than the (already improved) A/D portion. Also note that I'm just using a 2010 Quad core 2.8 Mac Pro. No fancy 12 core, etc. Also, if for some reason you're having problems with latency, the Omni has a low latency process that can be switched on for inputs 1-2, which is similar to how it worked on a 003, in that plugins on that track are bypassed, and it's a direct analog path. This feature is only on the Omni, not the HD IO's. When HD11 comes out, based on early reports, all of this will be dramatically improved, making HD Native a more viable option than ever. Hopefully some of this will aid your decision. If most of your plugins are native anyway, it may be overkill to go to HDX. |
As of now, my TDM HD 2 has served me very well. I can max out the voices and still play full HD video Pro-res 422 (1920X1080). I mix in exclusively in surround 5.1 and use the best plugins available for film sound. The plugins may never be ported to AAX DSP, plugs like Cedar Studio (DNS, Adaptive Limiter, De-Clip, De-Byzz), Equality, Izotope, Unveil, Waves Surround, Convolution verbs, etc. So right now, I can run my session with extensive native plugins but more and more I am needing more voices and more power. Since my plugins will probably never become AAX DSP, I would be better of going Native and save a bunch. But here is what "may" make a difference if I go HDX: If I could run all my verbs, effects (like echo, delay, etc), and may be stereo to 5.1 up-mixers, 5.1 reverbs, 5.1 compressor, etc. all in the DSP of the HDX card then I would have huge power to run the full 256 voices with extensive plugs. The problem is that there is NO aax DSP verb available. Altiverb, Revolver, Waves ITR they are only AAX Native...so...it is hard to see the benefit of paying for the HDX card when there is no software plugins - like the ones I mentioned- available. So even if I do buy the HDX I would be running most of it in native mode |
HDX cards do the processing for AAX DSP plug-ins
AAX Native plugs are handled by the host CPU if you are using the HDX card and interface for you I/O then all bussing and summing is handle but DSP on the HDX card
Is there a difference between AAX Native and AAX 64 bit? | rockguitarist1255 | AAX Plug-ins | 7 | 12-30-2015 01:00 PM |
Performance difference between Native and HDX | jjnssn | Pro Tools HDX & HD Native Systems (Win) | 27 | 09-21-2012 01:33 AM |
What is the difference between HD Native & HDX | ritb | General Discussion | 25 | 08-10-2012 07:34 AM |
Native, RTAS... What's the difference? | Che_Guitarra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-17-2008 06:11 AM |
waves native and TDM Difference | jwbyrd16 | Pro Tools TDM Systems (Win) | 0 | 06-03-2003 12:43 AM |
