Old 04-13-2011, 08:48 AM
DrummerGuy09 DrummerGuy09 is offline
Default AUTO Bypass Delay Comp on 1 track
Hello,
Was wondering if there was a way to bypass the Auto Delay Compensation on just one track. That one track has a seperate output not used for mix. I would much rather not have this mono tack delayed as much if it's not needed because it's not going into my stereo mix.
Old 04-13-2011, 03:14 PM
BillDog793 BillDog793 is offline
Default Re: AUTO Bypass Delay Comp on 1 track
There's no way to bypass a single track with automatic delay compensation, that I at least know of. From reading your post I don't know why you would want a track to not be delayed correctly with the others. Anyway a work around would be to delay the tracks like we used to have to. So look at the amount of delay the plugins are creating on a track by using ctrl(win)/command(Mac) + clicking the decibel readout in the mix window, twice I think. Then using the nudge feature, nudge your audio files the same amount of samples the plug-ins are creating. Be careful though, because if you change a plugin on a track, you are going to change the amount of samples that should be delayed. I don't know if having 1 track without any delay on it is worth the work, but good luck.
Old 04-13-2011, 05:26 PM
zedhed's Avatar
zedhed zedhed is offline
I think if you are sending the track out on it's own then it doesn't matter whether or not it's delay compensated since if it is ever brought back into a mix, it's essentially a floating track. Therefore it could be moved and placed wherever it fits.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 04-14-2011, 12:26 AM
crizdee's Avatar
crizdee crizdee is offline
Originally Posted by DrummerGuy09 View Post
Hello,
Command+control+click on the dly number in the delay comp filed under the track.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-14-2011, 11:27 PM
roberts roberts is offline
Ahh!! Chris you ruined it I was gonna post post what page number you could find in the manual ...
Old 04-15-2011, 01:48 AM
crizdee's Avatar
Manual! manual? wait a minute i heard about this so all this information is written down somewhere? why didn't somebody tell me this
Chris
Producer, Engineer,
www.ukmastering.com
[IMG] code is Off
Can't see Channel Strip plugin controls (Track, Preset, Auto Map, Bypass, etc). DJ Hellfire macOS 9 05-09-2015 08:38 AM
BUG mixdown print track records too early with delay comp Jaim Pro Tools 10 6 02-28-2012 10:16 AM
plugin bypass - delay comp change? James Drake Pro Tools TDM Systems (Mac) 3 12-04-2011 12:46 AM
Delay Comp problems again, Delay comp is RED but way below limits. soundeq Pro Tools TDM Systems (Mac) 13 11-29-2011 12:01 PM
Click track, drumagog, and delay comp. ericsvizeny Pro Tools TDM Systems (Mac) 6 02-18-2011 07:27 AM
