Old 02-20-2010, 08:03 PM
word_play word_play is offline
Default i5 Quad Core system, Error Msgs 9093 9094 and 6086...any help welcomed.
Hi guys,
New here and to Pro Tools. I recently purchased an Mbox Mini 2 that came packaged with Pro Tools 8. (I updated to 8.1)
I have followed Digidesigns steps to make sure my system is optimized for pro tools eg. Disabled usb power management...display performance etc.
When I first installed the program and went to record/playback I received the following:
"The operating system held off interrupts for too long. If this occurs frequently, try increasing the H/W Buffer Size" in the Playback engine panel (-6086)
After a TON of reading on this forums I found out that I had to disable certain power save features on my motherboard for my CPU.
I disabled the following:
CPU Ration Setting: Auto
C1E Support: Enabled
Hardware Prefetcher: Enabled
Adjacent Cache Line Prefetcher: Enabled
Max CPUID Value Limit: Disabled (Factory set disabled)
Intel Virtualization Tech: Disabled
Intel SpeedStep: Disabled
Intel TurboeMode Tech: Disabled
Intel C-STATE: Disabled
Rebooted the system and viola 6086 errors gone. However, after doing some testing, recording/playback, I receive error 9094 or 9093...
I just built this computer specifically for pro tools, what gives? I am lost
Any help would be very much appreciated.
Thank you.
SiSoftware Sandra
System
Host Name : CUESTASTUDIO
User : Cuesta
Workgroup : WORKGROUP
Processor
Model : Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
Speed : 2.67GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 1 Unit(s)
Type : Quad-Core
Internal Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 2x 256kB, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 8MB, Synchronous, ATC, 16-way, 64 byte line size, 16 threads sharing
System
System : System manufacturer System Product Name
Mainboard : ASUSTeK Computer INC. P7P55D LE
Bus(es) : ISA PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : American Megatrends Inc. 8.15
Total Memory : 2.99GB
Chipset 1
Model : ASUS ??? (D131)
Front Side Bus Speed : 1x 133MHz (133MHz)
Video System
Desktop Monitors/Panels : 2
Monitor/Panel : Plug and Play Monitor
Adapter : ASUS EAH4350 series
Imaging Device : Canon MX860 ser Network
Physical Storage Devices
Hitachi HDS721050CLA362 500GB (SATA300, NCQ, 14MB Cache) : 465.76GB (C:) (E:)
HL-DT-ST DVD-RAM GH22LP20 (ATAPI66, 48x CD-R, 48x CD-W, 6x DVD-R, 6x DVD-W, 2MB Cache, 192kB Flash) : N/A (D:)
Logical Storage Devices
Hard Disk (C:) : 97.65GB (83.24GB, 85% Free Space) (NTFS) @ Hitachi HDS721050CLA362 500GB (SATA300, NCQ, 14MB Cache)
Hard Disk (E:) : 368.10GB (367.44GB, 100% Free Space) (NTFS) @ Hitachi HDS721050CLA362 500GB (SATA300, NCQ, 14MB Cache)
CD-ROM/DVD (D:) : N/A @ HL-DT-ST DVD-RAM GH22LP20 (ATAPI66, 48x CD-R, 48x CD-W, 6x DVD-R, 6x DVD-W, 2MB Cache, 192kB Flash)
Peripherals
Serial/Parallel Port(s) : 1 COM / 0 LPT
USB Controller/Hub : NEC PCI to USB Open Host Controller
USB Controller/Hub : Standard Enhanced PCI to USB Host Controller
USB Controller/Hub : USB Root Hub
USB Controller/Hub : USB Composite Device
USB Controller/Hub : Digidesign Mbox 2 Firmware Updater
USB Controller/Hub : Generic USB Hub
Keyboard : HID Keyboard Device
Mouse : HID-compliant mouse
Human Interface : HID-compliant consumer control device
Human Interface : HID-compliant device
Human Interface : USB Human Interface Device
Printers and Faxes
Model : Microsoft Office Document Image Writer
Model : Canon MX860 series Printer
Model : Canon MX860 series FAX
Power Management
Mains (AC) Line Status : On-Line
Operating System(s)
Windows System : Microsoft Windows XP (2002) Professional 5.01.2600 (Service Pack 3)
Platform Compliance : Win32 x86
Network Services
Adapter : Realtek PCIe GBE Family Controller
Old 02-20-2010, 08:26 PM
TOM@METRO's Avatar
Default Re: i5 Quad Core system, Error Msgs 9093 9094 and 6086...any help welcomed.
One step that you seem to have missed is the one that requires a separate phisical drive for your sessions.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 02-20-2010, 08:31 PM
sw rec sw rec is offline
Second what Tom said, a partitioned system drive doesn't constitute a SEPARATE dedicated audio drove.
Old 02-20-2010, 08:37 PM
thanks for the quick replies guys... so do you think a separate internal SATA drive will do the trick?
Old 02-20-2010, 08:38 PM
sunburst79 sunburst79 is offline
Try disabling C1E as that has been known to cause issues wth PT
After that you might try locking the CPU ratio.
I would look into a WD or Seagate drive with 32MB cache for your audio drive.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 02-20-2010, 08:50 PM
thank you... I tried disabling C1E to no avail.
Thanks for the recommendation on the hdd. Question though before I go and spend more money I don't have.. is the partitioned drive the likely cause of the errors I am receiving? I have been reading a lot on these forums before I posted and I have read that a new seperate hdd doesn't always solve the issue. Yes, I know (again from my reading) that digi specifies a seperate hdd for audio, like I said, money is tight, just want to make sure.
Sidenote, I am thinking of downgrading to 7.3 as my friend is running it and has had no issues whatsoever, good idea? bad idea? thank you.
Old 02-20-2010, 09:04 PM
is 64mb cache overkill?
Old 02-20-2010, 09:21 PM
JMS40 JMS40 is offline
Sticky: General Troubleshooting - Pro Tools LE on Windows (XP & Vista)
Originally Posted by DigiTechSupt
IMPORTANT! You MUST use a secondary hard drive (not your main OS drive) for recording and playback of audio in Pro Tools. Recording or playback from the OS drive is known to be problematic and the cause of many different error types. If you are using your system drive and encountering errors, the first thing you should do is get a compatible drive. USB drives are not supported and are known to be problematic, so please do not use them with Pro Tools. If you're recording or playing back from a USB drive and are getting errors in Pro Tools, please switch to using a compatible external firewire drive or internal SATA/ATA/IDE drive and disconnect the USB drive.
Pro Tools supports recording and playback to a secondary drive that meets the following requirements:
7200 rpm or faster
9ms seek time or faster
Old 02-20-2010, 09:32 PM
cwsand's Avatar
cwsand cwsand is offline
Definitely COULD be but then again not neccessarily! I guess the point is you need to meet the requirements to run Pro Tools before you can really start troubleshooting. It IS possible to record to the system drive. I've actually had luck with that on a laptop but it's far from ideal. With a new pc, make sure you take baby steps as far as installing software/drivers. Download the latest drivers from the manufacturer's website and don't install anything you don't need for Pro Tools - at least until you get PT running properly. Then as you add things, if there's a problem at some point you'll know what's causing the conflict.
There's no reason you shouldn't be able to run 8.x once you get your system up to specs.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 02-20-2010, 09:37 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Originally Posted by cwsand View Post
Definitely COULD be but then again not neccessarily! I guess the point is you need to meet the requirements to run Pro Tools before you can really start troubleshooting. .
Excellent point
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Please help, getting errors 9092 9093 9094 6086 Mekko511 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 02-24-2010 11:00 AM
Error while playing back audio files in PT 8 (9093, 9094, 6086) need help!! slubbie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-27-2009 11:49 PM
Persistent 9092, 9093, 9094 and 6086 Errors on session playback MBOX2 Micro & Vista Sound Editing MunKee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-24-2009 04:13 PM
Dual Core Processor Affinity / 9093 9094 9129 ikelk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-21-2006 01:31 PM
haunted by the 6093,6086 error msgs! dalpal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-26-2005 08:44 PM
