Axiom 49, Pro Tools M-Powered 7.4 CS2 : "Unable to locate M-audio hardware"
Hi all. I just got an M-Audio Axiom 49 and Pro Tools M-Powered 7.4 with CS2 update. I got the latest Axiom driver from M-Audio's website. The filename is: MA_CMIDI_WDM_4.2.03v4.exe
Just for kicks I installed the latest Enigma software: Enigma_Ver_1.2.exe Every time I load up Pro Tools, I get the following message: "Unable to locate M-audio hardware. Make sure your hardware is connected and turned on." And then the program exits. Please help! Thank you! Eric |
The Axiom is not audio interface hardware; it's just a MIDI controller.
You need a compatible audio interface to be able to use Pro Tools MPowered.
I don't understand what you mean. Is there a different version of Pro Tools I can use with the Axiom? Is there other software similar to Pro Tools that would work with the Axiom? Did I buy the wrong hardware? I watched this video on M-Audio's website of a guy using an Axiom 25 with Pro Tools: http://www.m-audio.com/index.php?do=...ac9194704d9ba1
I also found videos on YouTube of people using the Axiom with Pro Tools: http://www.youtube.com/results?searc...rch_type=&aq=f Thanks for your help. |
The Axiom can be used with Pro Tools, but only as a MIDI controller to input MIDI and to play Virtual instruments. It is not an audio interface ("soundcard").
The Axiom is an M-Audio MIDI product/device. Pro Tools requires a compatible M-Audio AUDIO product/device to function. You need to have a compatible M-Audio AUDIO interface to be able to use Pro Tools. Period. You need a compatible "soundcard" to input and output the audio from Pro Tools. The Axiom is not a soundcard at all. It is just a MIDI controller. In all of those videos that you see people using the Axiom with Pro Tools, they are also using some kind of audio interface in addition to the Axiom to make Pro Tools function. There is a list of compatible M-Audio audio interfaces both on the M-Audio website, and on the product documentation for Pro Tools MPowered. The current compatible list of interfaces is as follows:
Ok thanks for the info. So the Axiom is essentially an instrument, like a guitar or piano, that requires some audio interface to input to Pro Tools. That's really strange.
So, is there an interface that would work with Pro Tools that would allow me to plug in my Axiom and a guitar, and optionally a mic? I would not want to spend more than $100-$200 for this. Also, I could exchange my Pro Tools for the regular LE version and use some other hardware. I could also use some software other than Pro Tools if it does the same job. My main goal here is to use my Axiom to control programs like NI Absynth, NI Battery, FL Studio, etc., record my classical guitar, and compose/mix/master using Pro Tools or some similar mixing software. What do you think? Cheers, Eric |
The Axiom is not what requires the audio interface. The Pro Tools software requires an audio interface. How did you intend to hear the audio output from Pro Tools? How did you intend to record your guitar? You need an audio interface. Quote:
(speakers/headphones). Quote:
Right on. Thanks for the thorough reply.
So I'm looking at the M-Audio Fast Track Pro (http://www.m-audio.com/products/en_u...kPro-main.html). It's about $160 on Amazon, and would allow me to plug-in my Axiom, guitar, and mic and keep my Pro Tools M-Powered software. This look like a good choice to you? Thanks again for the help. |
Fast track pro is a decent beginner interface.
The axiom has USB output so you don't need to plug it into the interface. It connects independently.
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
What he said.
If your looking for guitar/mic imputs for an interface, check out the Black Box, it what I use. The fast tracks work well, but keep in mind you need vitual effect software for sound, just like your midi. Black Box has them (amp sims, effects all built in), plus an input for an XLR mic. You can get one brand new with a pedelboard for under $200.00
Solution: "Unable to locate M-Audio Hardware..." Pro-Tools 8.0 M-Powered on 64 bit OS | bnorrgar | Pro Tools M-Powered (Win) | 6 | 06-26-2012 12:02 PM |
"Unable to locate M-AUDIO Hardware" - I've tried all I can... | PulS3 | Pro Tools M-Powered (Win) | 5 | 01-10-2011 08:42 PM |
"unable to locate m-audio hardware. Make sure device is connected and powered on" | bfreshmoney | Pro Tools SE and Essential (Win) | 3 | 09-01-2010 06:38 AM |
"Unable to locate M-Audio hardware." | LukeeeeBennett | Pro Tools M-Powered (Win) | 1 | 07-26-2010 02:23 PM |
Another "Unable to locate M-Audio hardware" thread | nem0nic | Pro Tools M-Powered (Win) | 9 | 04-03-2010 12:07 PM |
