Old 11-03-2000, 11:33 PM
airon airon is offline
Default Scrub Wheel - but seriously !
Hi there
New to this list, I wanna drop a big lump of eternal dissapointment here, unless someone will correct my troubled impressions with a pearl of wisdom.
Just yesterday the post team got its second day of training on the new Protools AV system and we're a tad dissapointed with what the scrub wheel on the Procontrol has to offer on functionality.
Coming from an AUGARN system, we're used to the scrubwheel being more than just that. It could MOVE/CUT/SHIFT-under-cursor material.
And that's not all. Who the hell forgot to add proper MARKER navigation ?! It's fine to advance forward with TAB, but how about backwards ??
Ok, so now you may start the crusification process, should I have missed those very useful post features in PT.
We are of course banging our heads with PT 5.01 with G4 and AVID hardware on MacOS9.04.
You'd earn yourself a big wet sloppy thank you if you point towards things our support guy has not been able to tell us in this matter.
Do I like PT? Why, who wouldn't? .
Tony
"My ego comes pre-shrunk" - Randy Thom
Old 11-05-2000, 02:25 PM
Jules Jules is offline
Default Re: Scrub Wheel - but seriously !
Can someone sumerize the progress since the first posts and what is still not working fully on the scrub wheel?
I find the curser 'way back' after using it. Is that my fault?
Jules
Jules
London, UK
Come hang with us here!
www.gearslutz.com
Old 11-05-2000, 03:11 PM
PTPerson PTPerson is offline
Jules, check your preferences "Insertion follows scrub"
That should help
Old 11-06-2000, 12:52 AM
John McDaniel John McDaniel is offline
Uhh.... the scrub wheel.
Well... here's some links to past discussions in the ProControl section of the DUC to give you a little history on the topic.
http://www.digidesign.com/ubb/Forum29/HTML/000003.html
http://www.digidesign.com/ubb/Forum29/HTML/000025.html
http://www.digidesign.com/ubb/Forum29/HTML/000027.html
http://www.digidesign.com/ubb/Forum29/HTML/000087.html
Be outspoken or it won't get done. Persist. Be unrelenting. Be a pest.
later, j mcd
Old 11-06-2000, 10:24 AM
More on scrubwheel action..
This time a wish list :
- Always available for moving cursor
It's analog, so let's use it for analog stuff.
- only disable transport if you realy
have to disable anything.
Take a look at the Augarn and then
look at the Procontrol.
Using an ethernet controller and
a USB keyboard at the same time
can't be that hard
- major feature. AUGARN a)SLIP/b)TRIM
function, meaning
a)the audio can be moved over a
static cursor
b)audio is moved within the region
window and again the cursor is static
Tony
Pearson TV/Grundy Europe
Old 11-08-2000, 06:33 AM
JKD99 JKD99 is offline
Hi Tony,
As far as the editing questions you mentioned.....
1) You can tab backwards by using option-tab
2) You can shift audio within a region (to value specified in "nudge") by highlighting region, then nudging forward or backward with control key pressed
3) I never use the scrub wheel anyway, I just use the Selector Tool with control key held down, which turns the selector into a scrubber
I realize all these things depend on using the keyboard instead of the ProControl, which I suppose defeats the purpose a bit. My system is set up so that the 32 fader ProControl is set up on a 7-foot long desk from Middle Atlantic, and it provides enough room IN FRONT of the ProControl to have the keyboard, remotes, AXIS panner etc. easily available. (This is also probably why the armrests on my ProControl haven't lost their paint ) Maybe the addition of the QWERTY keyboard in the new EditPack will help those who haven't got their keyboard so close at hand, but, another 8 grand? Anyway, hope this helps, and that I haven't completely missed the point of your post! Good Luck.
Joe Milner
Puget Sound
Los Angeles, CA
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Puget Sound on Facebook
Old 11-08-2000, 04:00 PM
This will only give me access to region bounds. I wanted to jump around using markers. In reality, we don't use this feature a LOT, but it should have been included. Perhaps it'll be in PT 5.1.
>2) You can shift audio within a region (to >value specified in "nudge") by highlighting >region, then nudging forward or backward >with control key pressed
Thanks. I wasn't told about this, so yeah, this is very nice. I like shifting ambiences that way if the start or end doesn't fit well.
>3) I never use the scrub wheel anyway, I >just use the Selector Tool with control key >held down, which turns the selector into a >scrubber
Shure, it's a start. Today we used an optical sensor mouse(Logitech Wheelmouse). The programable right hand mouse button to act as CTRL+click is a big help in dropping stuff. A lot of helpful features became aparent on the last day of our system intro, so I'm quite happy with PT for now, though I'll steadily nail stuff in to Digidesigns memory as often as it takes.
The new 5.1 version should be very interesting. We're waiting for support for UNITY too, which is in the making and almost done I hear.
In the meanwhile, DIGIDESIGN, where's simple cursor movement via the scrubwheel on the PC ??? Will it come in 5.1 ? Is it in the works at all ? Has anyone taken a look at AUGARN systems, to see what they've offered for almost ten years now ? I want that. If it's hard, then I'm sorry to say, that's your problem, 'cause you are the engineers for this thing. I wish you speed and bugless dev cycles.
Take care
Tony
Old 11-08-2000, 08:24 PM
You can jump around markers very easily.
Just hit enter and the memory location window will save the position with a marker in the timeline.
To fly between markers is simple:
.1. = memory location #1
.2. = memory location #2
etc, etc.
Moving the cursor with the scrubwheel:
A bit tricky at first but once you get the knack it's very easy.
1st: Hit the centre button of the quadrant (twice if the button is not lit) so it's flashing.
2nd: Hold down the Left and Right buttons of the quadrant and move the scrubwheel.....it moves the cursor. If you're wanting to select audio simply hold either the left or right buttons and move the wheel, it will select, deselect audio, plus trim sides of the selection.
If you want to move to different tracks use the up and down buttons on the quadrant.
This is very easy to use after a while.
[This message has been edited by PTPerson (edited November 08, 2000).]
Old 11-09-2000, 03:26 PM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
quote PT : ............. hold either the left or right buttons and move the wheel, it will select, deselect audio, plus trim sides of the selection.
Geez PT, for a moment you got me switching on my studio again and startup a session ........ I thought I read TRIM REGIONS with the scrubweel
Chris Lambrechts
Chris Lambrechts
Applications Specialist- Live Sound
Old 11-10-2000, 03:25 PM
"My goal is to make the Procontrol able to stand almost by itself. My boss rightly moaned about having to use three interfaces, mouse,keyboard&Procontrol, so I'm looking for features that made the system we're using at this time so elegant, to be included in Protools."
Bad news, it's not gonna happen. We had the same intentions.
Unfortunately due to some incredibly odd thinking digi assumed that the ProControl didn't need a keyboard or a trackball. (Do these guys really use ProTools or what?) They attempted it with the trackpad (which is entirely useless).
So now, for the luxury of having the keyboard and trackball on the same surface they're asking us to spring 8 Grand for the EditPack (too bad if you're not doing surround), I just love having to spend more money on what are fundamentals and it's totally beyond me that the original core doesn't have these.
So....if you're not going to buy the Editpack you have to fight between 3 surfaces, the ProControl, Keyboard and Trackball, incredibly not ergonomic and not good for the back either constantly changing your seating position.
Have fun, and get a chiropractor.
Pro Control Scrub Wheel in 7.2 iamnerdyrocker Pro Tools TDM Systems (Mac) 1 12-08-2006 11:02 AM
Scrub Wheel or Jog Wheel for PT JaredC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 05-07-2004 06:01 PM
Scrub Wheel Again! Jules ProControl, Control|24, Command|8 183 11-11-2002 08:11 PM
scrub wheel-NEW topic CLee ProControl, Control|24, Command|8 0 12-26-2001 08:18 AM
Nifty scrub selector doesn't work on Pro Control scrub wheel ???:eek: Jules ProControl, Control|24, Command|8 10 01-25-2000 10:52 AM
