Old 09-27-2020, 06:09 AM
Brandonx1 Brandonx1 is offline
Default Re: Processor affinity
Anyone getting hard crashes when switching sessions with this hack? I had to stop using it due to crashing whole switching session, which I have to do when reviewing with clients.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 09-27-2020, 09:03 AM
The Weed's Avatar
The Weed The Weed is offline
Nothing but trouble free using Processor Affinity as far as crashing is concerned - and most other things with the exception of the video engine choking on rare occasions. The Command switch won't work if you run Pro Tools as Administrator and it won't work if you start Pro Tools by double clicking a session icon. Some people have found better success, depending on the number of cores, by "turning off" a different core than 0 with Hyperthreading off or 0 and 1 with Hyperthreading on. You could also experiment with Processor Priority too.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 09-30-2020, 06:51 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
CPU Affinity took me from Unusable to Decent Performance
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
Old 10-01-2020, 01:59 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Originally Posted by ejinbc View Post
YES.
Affinity switch setting still required for me to get click/pop free performance at 24/96 with 64 sample buffer (OC 8700K; Win 10; MOTU 1248; PT 2020.9.1; NI Komplete; Waves Gold+). Without this setting the processor switching gets in the way (I think) and the sample que gets serviced too late - and then a click. For my 8700K FFE works best.
At 256 buffer and greater this switch is not required, and in fact can make PT a bit less powered YMMV. So I use 2 command prompts, one with an Affinity switch and one without.
For reference:
cmd.e x e /c start "ProTools" /affinity FFE "C:\Program Files\Avid\Pro Tools\Protools.exe
<remove spaces in ".exe" above can't post without added spaces>
ej9inbc
I have 14 cores. Do you know how to set affinity to only use CPU core 2-14?
From post above it seems like I should avoid using core 0 and 1?
Christian D Hagen | I7 Builds | PT/OS Compability Chart
Old 10-01-2020, 05:27 AM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
Christian, After opening Pro Tools, (but not a session) open task manager and right click on ProTools. Click on set affinity and uncheck core 0 and 1, leaving cores 2 through 13 checked. Then click on set priority and select High.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 10-01-2020, 06:05 AM
chrisdee's Avatar
Thumbs up Re: Processor affinity
Thanks.
Old 10-01-2020, 07:50 AM
ejinbc ejinbc is offline
C
14 cores looks like this (two 1's per core (i.e. 2 virtual cores per real core):
1111111111111111111111111111
which is this in HEX:
FFFFFFF
So in the command line I gave I would try:
FFFFFFE
which is this in binary
1111111111111111111111111110
That would shut off one half of one real core - which I find optimal. You can use the Windows calculator to do the Hex>Binary conversions.
BUT, THIS MAY DEPEND ON THE WAY THE AUDIO INTERFACE DRIVER WAS PROGRAMMED.
So, some experimentation is needed. I would load up a reasonably complex tracking session, set the buffers low (I use 24/96 with 64 sample buffer with a MOTU 1248), and then watch the activity monitor. When the sudden spikes stop (redlines) you have found the right setting.
WHY is this still a HACK Avid ? Seems pretty dumb we have to explain this over and over in the forum ! I have been using this since PT12.
A STICKY perhaps that explains the method and optimization strategy ?
Hope this helps.
ejinbc
Old 10-01-2020, 09:51 AM
The Weed's Avatar
See my post #8 on the first page for a HEX calculator. And yes, you will need to experiment to find which cores you should turn off above a Quad Core CPU. Although I'm puzzled how you have 7/14 cores. AFAIK, Intel's CPU's are multiples of 2 using even numbers.
SonoBus
Old 10-02-2020, 08:02 AM
EGS's Avatar
EGS EGS is offline
We used to have options for "# of Processors" and "CPU Usage Limit" in Playback Engine. Why are these options no longer available?
Avid?
Anybody?
Click for audio/video demo
Click for resume
Old 10-16-2020, 12:51 AM
mufi mufi is offline
There might be another optimisation, disabling Page Combining.
Anyone tried this? It's mentioned here:
https://avid.secure.force.com/pkb/ar...-Configuration
I tried it and so far I did not need to do the affinity trick anymore.
Long story short, Page Combining is a feature introduced in Windows 8.1 that reduces ram footprint of processes with same ram structure (or something like that). But it takes time to do so and it's often called by the os, so I guess it's not so good for apps depending on latency.
Win 10; PT 12.5.2; Processor Affinity ejinbc Windows 8 08-01-2016 12:33 PM
CPU Spikes, 12.5, and processor affinity... Work-Around? 59.9hz Pro Tools 12 12 07-22-2016 10:42 AM
Dual core problems with old 6.x rig. Affinity problem. scoobydoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-24-2007 08:12 PM
Set processor affinity fixed -9092, -9093 issues philwinkle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-31-2006 08:33 PM
Dual Core Processor Affinity / 9093 9094 9129 ikelk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-21-2006 01:31 PM
