Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 05-06-2020, 04:58 AM
huzzam huzzam is offline
Default anyone using ExFAT drives for sessions?
Hi everyone! I'm about to build a dual boot Win10/Hackintosh (Mojave), and would like my session & sample drives to be readable and writable from both OSes, so I don't have to have duplicates of everything.
The question is how to format the drives. It seems like ExFAT is the most compatible filesystem with both systems. Though it is native to neither, they both have stable read-write support. (The only other filesystem that I know of that has stable read-write on both is FAT32, which I'd really prefer to avoid.)
Has anyone here tried running sessions / sample libraries from ExFAT drives in MacOS and/or Win10? Any thoughts, or other suggestions?
thanks in advance!
~peter in athens
* Mojave Hackintosh : core i5-9600k / 16gb / 1tb nvme
* PT 2020.3 / Ableton Suite 9 / Spitfire Labs <3
* SoundToys + Lexicon PCM + Valhalla + i actually like stock plugins
* Steinberg ur-c / Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
Old 05-06-2020, 06:08 AM
ChuckS ChuckS is offline
Default Re: anyone using ExFAT drives for sessions?
I've used ExFAT without any issues on session drives. I don't see any reason why there would be any issue with a sample drive. I am now using a dual boot Mac and am using Paragon Software's HFS+ on the Windows side and their NTFS product on the Mac side. This gives me access to the system drives from either environment. Currently I keep my sessions on the Mac system drive so accessing them via PS HFS+ app is no issue. They also have an APFS product for Windows.
https://www.paragon-software.com/about/products-a-to-z/
PT 2020.5 DP 10.11 VEP 7.x MOTU M4 HP Envy 8G i7 Quad Laptop Win10 (x64 20H2)
PT 2020.5 DP 10.11 VEP 7.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad High Sierra.6
Old 05-06-2020, 06:13 AM
Great, thanks! Yes I've seen the Paragon stuff (and now that you mention it, somewhere I think I even have a license for their NTFS on Mac system, which came with some cheap hard drive at some point). I just prefer to use things that are natively supported if possible. Anyway I'll try ExFAT, and if it doesn't work well I'll try your other suggestions.
Old 05-06-2020, 06:31 AM
Tim R. Tim R. is offline
I would only caution that I've had issue with sample players (Kontakt etc) loading from ExFAT. Not sure if the problems I had have been resolved recently or not. This was a while ago.
Tim Reisig
System 1: Pro Tools Ultimate 2020.5, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 20.6, Rosetta 800 w/XHD card
Mac OS 10.14.6, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 2019.12 (no Hardware), Mac OS 10.14.6, MBP (Retina 13in, Early 2015, 3.1Ghz i7, 16Gig RAM)
Old 05-06-2020, 08:45 AM
Just an opinion, but I think I would use HFS for all but the Windows drive and install MediaFour MacDrive so Windows can read the rest of the drives
Old 05-06-2020, 10:13 AM
EGS's Avatar
EGS EGS is offline
+1. I use exFAT only for a drive used specifically for transferring MAC--->WIN or WIN--->MAC. For sessions: NTFS on WIN, HFS+ on MAC. Also, MacDrive works.
Desktop: PT 2020.5 / Win 10 / GIGABYTE GA-X58A-UD3R / i7 hex 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 2020.3 / Win 10 / HP ProBook / i7 quad / U-PHORIA UMC1820
Legacy: PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI001
Click for demo
Old 05-06-2020, 03:36 PM
Hmm, thanks. Macdrive is significantly more expensive than paragon hfs+... are there advantages?
exFat Support? JCBigler Pro Tools 11 4 02-13-2015 06:52 AM
ProTools 10.2 and ExFat yonah macOS 2 06-06-2012 07:45 AM
exFAT Drive + BFD Lite Problem JaimesMix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 04-05-2011 11:43 AM
Why are sessions being saved on 2 drives? lebowski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-05-2002 01:08 PM
