Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 08-21-2018, 07:41 AM
quadraphonics quadraphonics is offline
Default MTRX and S6
All,
I am having a bit of bother trying to get the s6 and the MTRX to communicate properly. I have the two talking, but I cannot control the Control Room sources of the MTRX from the monitoring page on the S6. Instead, the sources appear as tracks on the fader banks.
Any help would be appreciated,
Randall
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 08-21-2018, 07:50 AM
creativecontrol's Avatar
creativecontrol creativecontrol is online now
Default Re: MTRX and S6
Greetings,
Did you create a monitor profile to begin with? If not, start here:
http://avid.force.com/pkb/articles/h...Pro-Tools-MTRX
Jeff
Jeff Komar
Applications Specialist, Pro Audio
Old 08-21-2018, 09:14 AM
Jeff,
I did create a monitor profile. At one point this was all working. The MTRX is passing the correct audio and I can toggle between the monitor sources using the DADMan software .
Randall
Originally Posted by creativecontrol View Post
Greetings,
Jeff
Randall Smith
Audio Editor/Mixer
Denver, CO
Old 08-21-2018, 10:31 AM
its2loud its2loud is offline
Hi Randall,
Try rebooting the MTM or relaunching the WSControl software
Also,
on the DADMan software under Settings make sure EuCon is checked. If it is not, select it and restart the DADMan software.
Usually rebooting the MTM does the trick but check the other items just to make sure they are set.
Old 08-21-2018, 11:30 AM
ntp-jl's Avatar
ntp-jl ntp-jl is online now
Have you set the Eucon-mode in the monitor profile? I'm not in front of the DADman software right now, but if I remember correctly this is set for the monitor group. Right-click on the monitor group and select the Eucon-mode to be Control Room.
Jan Lykke
Business Development Manager
DAD - Digital Audio Denmark
Old 08-21-2018, 11:34 AM
Indeed, Jan is referring to this:
Let us know if you have access to sources either on the Soft Keys of S6 or on the Monitoring page of the Master Module.
best,
Jeff
Jeff Komar
Old 08-21-2018, 11:44 AM
ntp-jl's Avatar
That's indeed the one . Thanks Jeff.
Jan Lykke
Old 08-21-2018, 12:14 PM
Thank you all for your help.
I do/did have the Encon control on the monitor page set to Control Room. I do not have access to the sources on the MTM or softkeys. They come up as tracks on the faders when I have the DADMan software up.
Randall
best,
Jeff
Randall Smith
Audio Editor/Mixer
Denver, CO
Old 08-21-2018, 12:18 PM
It sounds like the monitor section is not bound to the S6. If your monitor profile is enabled, EUCON is enabled for DADman, WScontrol is running and you have active workstations on the surface, is the top Setup button on the Master Module (small circular button) at top of section containing mains encoder lit? This is also dependent on S6 and DADman versions. Please list DAD, PT and S6 versions currently.
Jeff
Jeff Komar
Old 08-21-2018, 12:33 PM
Jeff,
All three setup buttons are in fact lit, and I can see the monitor output path from the MTRX in the LCD window above the lowest setup button.
I did have this working at one point, so not really sure what is going on, but I appreciate the help.
Software:
DADMan: 5.2.0.14
WSControl 18.3.0.244
PT 12.8.3
Jeff
Randall Smith
Audio Editor/Mixer
Denver, CO
Pro Tools MTRX LukeHoward Pro Tools HDX & HD Native Systems (Mac) 170 12-29-2017 02:47 AM
MTRX Box JSR Avid S6 4 11-01-2017 12:46 PM
MTRX antonis Post - Surround - Video 2 10-26-2016 12:31 AM
Avid MTRX Rpro System 5 2 10-12-2016 07:40 AM
