Old 05-29-2014, 12:03 PM
Drawmer Drawmer is offline
Default Clock… again =(
Hi guys, it's me (again).
Again, I'm fighting the clock I can not synchronize with the signal AES.
It was like this:
192 (1) as the master clock - 8 channels adat ----> Mixer Ramsa DA-7
192 (2) as a slave clock - 8 channel TDIF ------> Mixer Ramsa DA-7
Two 192 interfaces are clocked via BNC
192 (1) clock output -------> 192 (2) clock input & 192 (2) clock output -------> 192 (1) clock input.
Everything worked perfectly!
When I decided add a third interface and get extra 8 AES channels to mixer, I could not do it
I clocked it like existing ones (loop clocking).
192 (1) clock output -------> 192 (2) clock input & 192 (2) clock output -------> 192 (3) clock input & 192 (3) clock output -------> 192 (1) clock input.
But no sound in mixer from AES channels. Adat & tdif sounds ok, adat and tdif slots marked "lock" in mixer's screen, but aes slot marked "unlock".
I think maybe my mixer need an extra BNC-sync especially for AES channels?
192 (1) clock output -------> 192 (2) clock input & 192 (2) clock output -------> Mixer clock input & Mixer clock output -------> 192 (1) clock input.
Now mixer is clocked through adat. If I plug it in to the clock loop BNC like interfaces? Now mixer synchronized through adat and sounds well.
Or plug mixer to x256 clock?
Old 05-29-2014, 12:50 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Clock… again =(
You must not have any other boxes in the loop sync, besides Digidesign/Avid HD interfaces. That's a rule #1. Every other box needs to be clocked from the ext.clock output.
Now I'm not sure, because I don't use TDIF, but I suspect that setting one of the interfaces to TDIF makes the ext.clock run a 256x superclock. I don't know whether it makes *all* interfaces output superclock or just that one. But in any case, you need to know if your digital devices require normal (1x) clock or the superclock (256x). Once you've sorted that out, you know what to do:
1) run wordclock from ext.clock of the interface that uses TDIF to all boxes that require the 256x superclock
2) run wordclock from ext.clock of the interfaces that DO NOT USE TDIF to all boxes that require 1x normal clock
3) in case the boxes requiring normal clock don't get lock, split the loop sync which always outputs 1x normal clock. DO NOT put the other boxes to the loop, but instead use a passive T-splitter and "steal" the word clock from there.
Then report back.
Janne
Old 05-29-2014, 02:14 PM
Bill Denton Bill Denton is offline
And don't forget termination...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 05-29-2014, 09:27 PM
JFreak's Avatar
Yep. Passive splitting and forgetting termination drop signal level so things just might barely work or barely not work because either or both of these... BUT, wordclock is a digital signal so as long as the signal is "good enough" things keep working -- just that you don't ever know how close to disaster you're working, it just either works or not.
Janne
Old 05-31-2014, 12:22 PM
Thank you!
I did everything as you wrote. Rechecked everything again, thought again, and decided that your diagram is correct. Everything SHOULD work. Adat and TDIF work fine, AES does not work.
I did a few more experiments with equipment and connections, and came to a simple conclusion: the mixer's AES-board is faulty. Some malfunction in board. I'm sure this on 95%!
I have a Solomonic decision: I just replace the wrong AES-board to the TDIF-board. This format is already running, there is no reason to reinvent the wheel).
Thank you very much for your advice!
Old 06-10-2014, 07:00 PM
the dude's Avatar
the dude the dude is offline
Word clock is TTL not a digital audio signal
http://www.studio-techservices.com
ÒÓ
[email protected]m
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 06-10-2014, 09:24 PM
JFreak's Avatar
I said digital signal, not audio.
Janne
Problem detected with audio clock. Check your clock source and sample rate. sleeptalken Windows 7 08-10-2021 01:17 PM
Problem detected with audio clock. Check clock source and sample rate are correct mongrel8686 Third Party Interfaces 11 08-01-2013 08:42 PM
Problem detected with audio clock. Check that your clock source and sample rate are c Solow1nonly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-06-2011 08:22 PM
problem detected with audio clock. check that your clock source and sample rate are c angeleda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-05-2010 07:09 PM
"Problem detected with audio clock. Check that your clock source and sample......... ASD15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 03-26-2010 03:40 PM
