Old 06-22-2013, 06:51 AM
Mark8Studio Mark8Studio is offline
Default PT 11- HDX1 - No Output
Avid I/O 8x8 1&3 Analog out -> C|24 1&3 input
Downloaded & installed Pro tools HD Driver
Downloaded & installed Pro tools 11
Setup Peripherals
Setup corresponding C|24 I/O settings
Setup settings & preferences
* Sessions will open and play but there is no sound output. Meters do not move.
* System usage is showing little usage on CPU and the HDX usage is completely unused. No Voices Used on 10 Audio track / 4 Buss / 20 Plug-in session
* When selecting a different output any track “dsp n/a” is displayed.
PT10 still works fine.
Old 06-22-2013, 04:51 PM
Default Re: PT 11 HDX1 - No Output
Old 06-22-2013, 05:03 PM
Bharath's Avatar
Bharath Bharath is offline
Default Re: PT 11- HDX1 - No Output
What platform/machine configuration etc?
:: Bharath
Pro Tools Software Team
Old 06-22-2013, 05:32 PM
Mac Pro 2x Quad Core (2010), Mountain Lion OSX /up to date. Sorry- forgot to list this information.
Old 06-22-2013, 05:41 PM
Bharath's Avatar
May be you checked this already
Do you see any meter activity on your interface when using HDX?
Can you double check if the mapping between buses and IO's are correct in IO Setup page?
Does built in output work?
Thanks
:: Bharath
Old 06-22-2013, 08:06 PM
Bill Denton Bill Denton is offline
Setup Peripherals
Curious as to why you're using 1 & 3 for in's and out's instead of 1 & 2.
If you went into I/O setup and clicked the Default button on each tab (must do it on each tab) it is probably setting everything to the more common 1 & 2.
And any I/O issues would probably also "ripple" to your C|24. While the C|24 uses 1 & 3 for the left/right monitor inputs, that is probably not the outputs you would use from your HD I/O...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 06-23-2013, 05:54 AM
Thanks
There is no meter activity on the I/O
Mapping in is correct since all Pro Tools C|24 Defaults were selected.
Pro Tools Aggregate DOES give me output & Metering
Thanks
Old 06-23-2013, 06:04 AM
When using DB-25 to DB-25 cable, there are no options of using alternative outputs from the Avid IO. All C|24 - Pro Tools recommended defaults were selected accordingly. (1&3 outputs as the Main) which are automatically sent through DB-25 to the C|24 1&3 inputs.
Thanks
Old 06-23-2013, 07:14 AM
Bharath's Avatar
That “dsp n/a” could be a potential problem. Let me ask around.
:: Bharath
Old 06-23-2013, 08:55 AM
Resolved:
Deleted both new installers (PT10 & 11)
Downloaded PT10 & 11 again
Clean uninstalled everything Avid
Restarted
Installed PTHD Driver
Restarted
Installed PT10.3.6
Restarted
Opened PT11 download, Dropped Pro Tools Icon into Applications
Opened PT11 and everything works perfectly.
Thanks.
HDX1 and interfaces Alécio Costa Pro Tools HDX & HD Native Systems (Mac) 2 10-30-2012 07:50 AM
FS: New ProTools HDX1 system sextrosound Buy & Sell 0 08-20-2012 09:26 AM
HD3 accel to HDX1, Happy? DetroitT Pro Tools HDX & HD Native Systems (Mac) 32 06-16-2012 12:21 AM
HDX1+96 IO to HD3 and HDX2+96 IO to backup betojapa VENUE Live Sound Systems 4 05-10-2012 05:34 AM
Pro Tools/Hdx1 ?? Scott Fahy VENUE Live Sound Systems 2 08-07-2007 03:27 PM
