Old 03-21-2011, 08:20 AM
Mister_Riff Mister_Riff is offline
Question Pro Tools 8.0.1: install disc doesn't work (Eleven Rack)
My Pro Tools 8.0.1 install disc that came with my Eleven rack doesn't seem to work?
When I try to install it hangs on "Pro Tools Reference Guide.PDF" and seems to locate this file on the CD but fails and after 1 hour I shut down the installer.....
Anyone got similar experiences or advice? Or is there maybe some way I could get a download or another disk? (Calling support could be a problem since I live in Belgium and there is only one phone number for Europe. This could be very costly!)
System (laptop):
Windows 7 (x64)
I7 620m processor, 6gig DDR3 Ram
What I've tried/done:
- Creating an ISO out of the disc: doesn't work, says it is corrupted
- Deleting the data, rebooting and trying again: same problem appears
- Running it as an administrator and/or running it under XP (to reduce comptability problems)
- Trying to install without hooking up my Eleven Rack
- Downloading from the avid website using my code found on the back of my CD Booklet: says this is unvalid ?!?
Update 1: problem seems to be fixed
I ran the CD in an external DVD drive and was able to install Pro Tools . However: I'm still not able to create an ISO file out of the disk ...
I then hereby apologise for this thread since the problem has been resolved. If a moderator sees this: my thread may be removed
Last edited by Mister_Riff; 03-21-2011 at 09:50 AM. Reason: Problem seems to be fixed
How to connect other hardware to Eleven Rack and make it work in Pro Tools 11 TENM Eleven Rack 0 03-11-2014 05:55 AM
will eleven rack work with pro tools 11 maxidud999 Eleven Rack 8 02-07-2014 10:32 AM
Eleven Rack Pro Tools 8 disc doesn't work spasm Eleven Rack 4 01-29-2012 09:01 AM
New Eleven Rack...can't install Pro Tools 8 Webb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 01-26-2011 03:19 PM
Bought an Eleven Rack and Pro Tools won't install, help!!! kgtele Pro Tools TDM Systems (Mac) 1 06-11-2010 01:33 AM
