Old 12-19-2009, 11:20 PM
quantize quantize is offline
Default 8.0.3 LE, why do i have an Eleven Rack Pref Panel now?
any particular reason any of my RAM or system resources would be wasted by installing a preference panel for a box i do not own?
shabby!
quantize
Pro Tools 10.3.9 / Cubase 8 / Reason 8 / OSX 10.9.5
Mac Pro 2 x 2.8 gHz Quad Core Intel Xeon / 14GB Ram
UAD Apollo Quad / MOTU 828 mk3
Avid Artist Control / Blackmagic Design Intensity Pro
Old 12-20-2009, 02:32 AM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: 8.0.3 LE, why do i have an Eleven Rack Pref Panel now?
It's there for users that run systems (such as in a studio) where someone might bring in an Eleven Rack. Or users that have an Eleven Rack and another LE interface. There are users that have both here on the DUC.
If you are never going to use it, preference panels are easy to remove:
Right Click or Control Click on the pref pane in system preferences, and choose remove.
There are also some plug-ins that you can remove if you never use an Eleven Rack, listed on this page.
Administrator
Old 12-20-2009, 03:08 AM
Thanks for the reply...
quantize
Old 12-20-2009, 07:16 AM
bsmith23 bsmith23 is offline
the Mbox2CS that sneaks into the /Library/StartupItems/ is irksome as well.
Old 12-24-2009, 02:18 PM
I can't say the logic behind this kind of stuff makes sense...let people install the drivers if they need them...it's more than a bit rude.
quantize
Old 12-27-2009, 11:00 AM
revans revans is offline
I am not a musician. (Gasp!)
I use my simple ProTools MBox2 Mini and a MacBook Pro (Snow Leopard 10.6.2) setup for voice work.
I will never plug in an Eleven Rack into my system.
NEVER!
1) Is there ANY reason for me to NOT remove the Eleven Rack from my Mac's System Preferences?
2) Is there ANY advantage to me for having all those Eleven *.dpm files taking up disk space on my MacBook? (I assume they only work with the Eleven Rack's outboard DSP.)
Old 12-28-2009, 11:29 AM
DigiTechSupt's Avatar
The logic is that you can connect any Digi device and it will work with your system without having to find your installer CD/DVD or downloading an installer.
If we don't install them, we get complaints from people in the opposite situation, so it was a decision of 'which is more convenient'.
The files don't do anything without the device attached, so they're completely harmless.
If you're never going to attach an Eleven Rack or purchase/use the Eleven plug-in, then it's find to remove the panel. Same goes for the dpm files.
Avid Audio Tech Support
Support FAQ
Old 12-28-2009, 11:33 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Originally Posted by DigiTechSupt View Post
If you're never going to attach an Eleven Rack or purchase/use the Eleven plug-in, then it's FINE to remove the panel. Same goes for the dpm files.
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 12-28-2009, 03:18 PM
Craig F Craig F is offline
This leads me to thequestion of why the installer(s) have been dumbed down?
use to be able to have a lot more control of extras at install
Thank you,
Craig
Old 12-29-2009, 05:18 AM
yet the silence over the coremidi bug is deafening..!
how come you can always get responses to trifling issues and total silence over big whopping bugs from DAW companies?
quantize
Mac Pro eleven pref. problem ? bennym macOS 4 03-20-2012 05:12 PM
Eleven Rack control panel freezing MichaelUR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-04-2011 05:50 AM
Eleven Rack Control Panel Problem MichaelUR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-01-2011 12:13 AM
Eleven Rack icon in my WinXP Control Panel? SixChurchStreet Pro Tools M-Powered (Win) 1 12-27-2010 11:56 AM
MBox 2 On Mac pro tower no "system Pref control panel"? herov 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-21-2009 03:30 PM
