Old 08-20-2008, 12:21 PM
murdafew murdafew is offline
Default The current playback engine does not support a sample rate of 44.1 khz
Im trying to open up sessions on ptmp 7.4 and just when the sessions is about to load an error pops up and says the current playback engine does not support a sample rate of 44.1khz could anybody help me
Old 05-08-2010, 11:52 AM
Riverrat Riverrat is offline
Unhappy Re: The current playback engine does not support a sample rate of 44.1 khz
I am having the same trouble with windows and pro tools 8. I can not seem to find answer either. I have check my playback setup and options. Come on guys, someone must know the answer.
Old 05-08-2010, 11:54 AM
KingFish KingFish is offline
Default Re: The current playback engine does not support a sample rate of 44.1 khz
You guys using ANY external converters, or devices with SPDIF, or Optical out ?
David
- MacPro 6,1 Intel Xeon E5 2.7 GHz 12-Core 128 GB 1066 MHz DDR3
- HDX II Sonnet xMacPro Server
- 16x16 HD i/o x 6
- PT 2018.10
- OS X 10.14.4
- ProTools Dock / PT Control
Old 05-10-2010, 06:55 AM
jimi_d2006 jimi_d2006 is offline
This happens to me when I have Youtube up and try to start Pro-tools
Old 05-14-2010, 03:21 AM
MultiCore's Avatar
MultiCore MultiCore is offline
Looks like an external device is controlling the clock. And it's not set to 44.1kHz.
www.dragonmusic.nl
Current Playback Engine does not support sample rate sharpo07 Pro Tools 11 7 01-08-2016 05:32 AM
The current playback engine does not support a sample rate of 48 kHz. allegrarc macOS 9 11-27-2014 09:43 PM
the current playback engine does not support a sample rate of 47.9 kHz mikevarela Post - Surround - Video 3 03-30-2013 09:26 AM
The Current Playback Engine Does Not Support A Sample Rate of 44.1Khz ZiviMusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-29-2013 02:05 PM
The current playback engine does not support a sample rate of 192k Oblivious74 macOS 3 06-01-2011 07:08 PM
