Old 07-24-2007, 07:42 AM
Markus Mehlau Markus Mehlau is offline
Default spdif-in of mbox doesn\'t work with core audio apps?
connected the optical out of my macbook pro to a behringer src 2496 for conversion. then went from the spdif out of
the behringer to the mbox spdif in. problem: somehow the spdif signal is lost when a core audio application (e.g. garage band) is started - mbox doesn't receive a spdif signal any more.
when using protools le the same routing is working just fine.
what maybe causes this problem: in audio midi setup only 2ch-32bit is selectable as audio input format. the behringer src is not capable of converting to 32bit.
any ideas?
Mbox, Core Audio & Tiger Do Not Work Together The Dougfather 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-22-2005 01:06 PM
Can two apps use Core Audio at the same time? willson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-01-2003 07:58 AM
MBox SPDIF I/O w/Third Party Audio Apps? (OSX) Robert George 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-06-2003 06:53 PM
Core Audio (Limiting which Apps can use it.) carouzal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-19-2003 08:49 PM
Mbox Core Audio SPDIF IN/Out? ru2b12 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-21-2003 09:05 AM
