Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 10-15-2006, 04:44 PM
gjohung gjohung is offline
Default M-Powered and M-Box Coexist
Can M-Powered and M-Box Coexist and run on same system same install/copy of ProTools LE?
Apple: MBP 2.53 - 4G RAM HDD 500G, iMac 27 inch 1TB
ProFire 2626, MBox Micro, PTMP 8, NIs, Strike, POD Farm, Logic 9, EJ Strat, 52 Tele RI, MB Mk 3, PRS CE22, Epi Casino, PBass, Variax, L6XTL, M13, DRRI, BM iGuitar, GR-33, KeyStation 88, Axiom 49
Old 10-15-2006, 06:35 PM
Kryst Kryst is offline
Default Re: M-Powered and M-Box Coexist
Pro Tools LE and Pro Tools M-Powered can work together on the same computer as long as you are using Pro Tools Le 7.1 and Pro Tools M-Powered 7.1 (or higher).
You will not be able to use the mbox in M-Powered, but you can use it in Le on the same system.
Kryst
Old 10-16-2006, 01:27 AM
I own M-Box...but just getting M-Audio will not let me use the PTLE already installed in my system? So PTLE and PTLE-MPowered is totally discrete/separate apps?? I have access to Digi002,,I can swap the hard ware back and forth between MBox and 002. Does that mean I can't switch back and forthe between MBox,002 and MAudio Stuff??
Old 10-16-2006, 05:23 AM
cheekypaul cheekypaul is offline
Digidesign software can only use Digidesign hardware.
M-Audio Software can only use M-Audio hardware.
Swapping sessions between Digidesign and M-Audio PT LE and M-Powered is flawless.
Mac Computers/PT12/Lots Of Lacie D2s
Old 10-16-2006, 06:05 AM
To further elaborate, you can not use Pro Tools M-Powered with an 002 or mbox (or 001). These devices are LE strictly. You need an M-Audio device compatible with Pro Tools M-Powered. But yes, as stated, once you have LE and M-Powered (and an M-Audio device), you can open a session back and forth in the two separate programs.
Kryst
Can't m-powered and HD coexist? DUCHUNTER Pro Tools TDM Systems (Win) 9 01-12-2011 01:51 PM
Can HD TDM & PT Native Card Coexist? magnet macOS 5 01-04-2011 04:20 PM
Can PT 6.9 and PT 7.0 coexist on the same system? PTFan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-16-2005 12:10 PM
Can PT 6 TDM and LE coexist on same computer? Captain Crunch Pro Tools TDM Systems (Mac) 5 02-17-2003 02:46 AM
Could an HD and an 001 system coexist on the same G4? Basil's Wrathbone Pro Tools TDM Systems (Mac) 4 02-14-2002 11:43 AM
