  #21
Old 05-31-2020, 09:28 AM
Oli P Oli P is offline
Default Re: Lag/spinning beach ball every 10-20 seconds
Seems like I got my issue fixed too.
I had to empty the plugin folder ...and gradually bring them back.
Turned out there were some 32bits plugins in there...that likely caused it to crash...but didn't pose any problems in 2019.12
www.olipoulsen.com
iMac27 i9 3.6 (2019) / 64 GB Ram / OS 10.14.5
Apollo 8 / PT Ultimate 2020.5
  #22
Old 05-31-2020, 09:34 AM
Coll Coll is offline
I am on a new Mac Pro that should be screaming and it is doing the same thing. Lag Beachball every few seconds. Does not crash but on playback the cursor freezes and then a few seconds later catches back up. Same with key strokes... Kinda sucks.
C.
Coll Anderson M.P.S.E.
  #23
Old 05-31-2020, 10:25 AM
Tim R. Tim R. is offline
C.
Pretty sure the pref fix I mentioned early should fix this for you Coll. Under Operations tab pref, de-select "send anonymous data to AVID". If this DOESN'T work, you can try turning off your internet connection (more problematic though).
Tim Reisig
System 1: Pro Tools Ultimate 2020.5, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 20.6, Rosetta 800 w/XHD card
Mac OS 10.14.6, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 2019.12 (no Hardware), Mac OS 10.14.6, MBP (Retina 13in, Early 2015, 3.1Ghz i7, 16Gig RAM)
  #24
Old 05-31-2020, 11:50 AM
simontheoracle simontheoracle is offline
Issue should now be fixed.
  #25
Old 06-01-2020, 08:22 AM
juniperian juniperian is offline
Issue is gone here. Unchecking the anonymous data pref did nothing for me. I disconnected my Ethernet, which stopped the spinning balls. I reconnected an hour later, and the problem was gone, with or without the anonymous data pref checked. I worked all day yesterday after this with no issue.
Our guess is that a change was made on an external server, most likely Avid’s, that caused a sudden problem for a large number of users. Perhaps they fixed it late morning yesterday. If you unchecked that pref, try re-checking it to see if the problem returns. It hasn’t for me, or for one of my friends.
  #26
Old 06-01-2020, 09:58 AM
the.engineer the.engineer is offline
YES I saw this too. I installed the Radio Silence app (macOS) to prevent any network connections.
Fixed it for me.
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Pro 5,1 (Mid 2010) | 3.46GHz Six-Core Intel Xeon | 32GB Ram | AMD Radeon RX 580 8GB | Apple 27" LED Cinema | 500GB Samsung 960 EVO M.2 SSD System Drive | 1TB WDC Sample Drive | 512GB Samsung SSD Audio Drive (temporary) | UAD-2 Quad PCIe
Mojave 10.14.6 | Pro Tools Ultimate 2019.12 | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
  #27
Old 06-01-2020, 01:01 PM
Looking up the Radio Silence App now...
My machine is up and happy.
C.
  #28
Old 06-02-2020, 04:10 PM
jg707's Avatar
jg707 jg707 is offline
I've been having the same issues, PT 2020.3 on Catalina 10.15.4
It all cleared up as soon as I turned wifi off.
Is there a way to turn off network access in PT? I'm not finding it....
Thanks
  #29
Old 06-02-2020, 05:51 PM
Ben Jenssen's Avatar
Thanks
Radio Silence | Network monitor and firewall for Mac
This is a super simple, effective and cheap utility to block apps from net connection.
Highly recommended.
spinning beach ball monet Pro Tools 2018 2 05-07-2019 12:43 AM
Spinning Beach Ball.... Help StevieDebe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-07-2011 06:40 AM
Spinning Beach Ball Of Death On G5? logandrum Pro Tools TDM Systems (Mac) 0 08-03-2007 12:07 AM
spinning beach ball when doing almost anything... Muzoid Pro Tools TDM Systems (Mac) 4 01-01-2006 08:57 AM
Going NUTS w/ Spinning Beach BALL... pls hlp Aluminum Jockey Pro Tools TDM Systems (Mac) 36 09-08-2004 05:10 AM
