  #41
Old 06-20-2019, 05:10 PM
BScout BScout is offline
Default Re: 5.1 file channel order
Originally Posted by AndrewAction View Post
After a couple of members requested Avid to look into issues raised about the KB article one of the techs pointed out "That KB article is not wrong because it's not really about EXPORTING - it talks mostly about importing, display order (on the timeline), meter order and audible channel output order. When exporting there are various factors that dictate the channel order of the resultant file - for example, exporting as AIFF will result in a different channel order to exporting as WAV."
Also the last Q/A which mentioned exporting in the Working with SMPTE-ordered multichannel files in Pro Tools article has been updated June 20 2019.
Andrew
I don't know what kind of double-speak that tech is talking but the KB article we are all talking about is the one you linked to at the end just now. You can clearly see that is so in Paulo M's post earlier (post #3) and Tom Lowe's post (post #21) earlier. It was also wrong at the end of 2018 when we discussed it in this thread: http://duc.avid.com/showthread.php?t...light=Its2loud
And it was wrong.
They updated it today to where it is right. But previously it had the incorrect information and it has been that way for a very long time.
There's saving face but no one was confused between exporting and importing.
The internet never forgets:
Last edited by BScout; 06-22-2019 at 02:39 PM. Reason: screenshot from January. All caps removed since just noticed it is against forum rules
  #42
Old 06-20-2019, 06:26 PM
jeffro's Avatar
jeffro jeffro is offline
If you are referring to the last QA in the article ("Not at this time.") then yes, that was incorrect so was updated today. Our tech also added 7.1 info in the first QA pair. I guess it would have been more accurate if our tech said "Other than that last QA pair..."
Any other feedback on that KB article? Also, would it help to merge threads to bring this all together? Thanks.
linkedin
  #43
Old 06-20-2019, 10:58 PM
Merging would be good so this isn't rehashed a third time.
The one line in the QA that should be changed is this one:
It is possible to export WAV files in SMPTE order at this time, but only files up to 5.1. Pro Tools uses the BWF Wave Extensible Standard channel order when exporting WAV files, which is the same as SMPTE order up to 5.1.
"Possible" doesn't really cover it. For BWF, 5.1 SMPTE order is the only way the file will be exported.
Right now it is open to interpretation when there is actually no choice.
  #44
Old 06-20-2019, 11:57 PM
Pete Gates Pete Gates is offline
Totally agree with Bscout. This has been the subject of so much pointless debate, occasionally verging on argument, when in fact it’s 100% clear, defined and non-optional.
Pete
  #45
Old 06-21-2019, 07:10 AM
its2loud its2loud is offline
Thanks BScout. You bring up a good point. Best to not leave it up to interpretation. I think it’s in Avid’s best interest to release a specific document detailing all the channel orders Pro Tools outputs for specific file formats and widths.
  #46
Old 06-21-2019, 04:25 PM
paulo m's Avatar
paulo m paulo m is offline
Completely agree!
Regards,
Paulo M
MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura
Protools Studio 2024.3
  #47
Old 06-21-2019, 05:13 PM
jeffro's Avatar
Sounds like just removing that first sentence should address this concern, but please reply if additional definition would help. Thanks!
linkedin
  #48
Old 06-21-2019, 06:20 PM
Striking the first sentence helps. The second sentence is convoluted in it's "A uses B when doing X and B = C therefore A uses C" approach.
So changing
to
When exporting WAV files, Pro Tools uses the BWF Wave Extensible Standard channel order which is in SMPTE order up to 5.1.
is a more direct answer to the Q part.
  #49
Old 06-21-2019, 10:26 PM
Jeffro,
One can further expand on that answer with....
“When exporting AIFF files, Pro Tools uses (insert channel order here) order up to 5.1 and when exporting Quicktime files, Pro Tools uses (insert channel order here)up to 5.1.
Then go on to detail 7.1 channel order.
Thanks.
  #50
Old 06-22-2019, 03:44 PM
paulo m's Avatar
What about changing the code so that users can choose what channel order they want to export to, despite the format? I think that it would make much more sense.
Regards,
Paulo M
HTML code is On
Pro Tools 5.1 export channel order Charles Deenen Post - Surround - Video 27 06-08-2016 06:58 AM
CAF channel-order still wrong in 9.0.5 Arno Peeters Post - Surround - Video 3 07-26-2015 07:55 AM
Locked Channel order in Bus bcslaam Pro Tools 11 3 08-29-2013 12:11 PM
