  #21
Old 11-01-2013, 08:38 PM
CygnusX-1Bk2 CygnusX-1Bk2 is offline
Default Re: OSX 10.9 Update
If you already upgraded to 10.9 there is no other way than re-installing from empty hard drive.
You need to download 10.8 from App Store and burn the installer to 8GB USB stick (there are plenty of tutorials how to do that, just google). Then start from that memory card, use disk utility to empty the drive, and install.
EDIT:
Here's the link to mountain lion in case you haven't purchased it before 10.9 came out
Thanks for the link! I am in the process of putting a machine together for 11 and 10.9 bit me when it came out. One day later I wouldn't have noticed. This helps.
I will choose,
Freewill
http://jimdiazaudio.com/
  #22
Old 11-02-2013, 11:30 AM
CraveMac CraveMac is offline
At the minute I am running a Co-install of PT 10 & 11.
Anyone know the state of PT 10 and Mavericks then.
After reading someone is testing on a backup hard-drive, I am looking at completely cloning my mac and giving it a test on that. More than likely do two clones. One so I can completely revert back before I started messing around and one to test mavericks on externally.
My mac will probably end up in a bin...
  #23
Old 11-02-2013, 12:16 PM
Mavericks support is not there yet, sit tight and wait...
  #24
Old 11-03-2013, 06:24 AM
That's what I am doing. Are avid working on PT10 compatibility though?
  #25
Old 11-03-2013, 06:38 AM
YYR123's Avatar
YYR123 YYR123 is offline
Whoo that's a good question - if we are guessing (and I am) I would say yes
They have a pretty good record of keeping up with apple's silliness and o/s releases even for the past release of Pro Tools. (In this case 10)
Daniel
  #26
Old 11-03-2013, 02:25 PM
serstickman serstickman is offline
PT 10.3.7 on 10.9 is running fine here. YMMV :)
PT 12.5.1, Reaper, S1, Cubase, Logic 9 & X, Mac Pro 4,1>5,1 Yosemite 10.10.5
  #27
Old 11-04-2013, 04:46 AM
psychotoddler psychotoddler is offline
BTW if u buy a new Mac it's going to come with mavericks, so impetus enough for avid to get it working.
iMac Haswell 27" 8 Gb
OS 10.8.5
Digi003, Eleven Rack
PT 10.3.7, 11.0.3
Logic X
Fender Bass and Strat
Lotsa other crap
  #28
Old 11-04-2013, 05:05 AM
YYR123's Avatar
That's weird they don't give you the option to have the past OS loaded when you order your computer - for as much money as those things are they ought to give you at least that option
Daniel
  #29
Old 11-04-2013, 06:08 AM
Some times you could get the Apple Store to load a older version on. The qualifier was if that particular hardware came with the older version at some point. If its new or recent hardware your out of luck.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
  #30
Old 11-04-2013, 06:56 AM
panamajack's Avatar
panamajack panamajack is offline
Logic X only requires 10.8.4. PT11HD is current as far as I am concerned.
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon
HD Native cant Update Firmware after installing PT9.0.5 Update Aditu Pro Tools HDX & HD Native Systems (Win) 72 11-27-2012 03:57 PM
10.3 Update - Windows shutdown issue has returned. Update at your own risk. crm0510 Windows 14 09-19-2012 01:50 PM
10.5.6 update. Is it safe to apply the system update from 10.5.5? SBCCMusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-02-2009 02:27 AM
Windows Update Vs Apples Software Update sunburst79 General Discussion 2 07-14-2007 06:40 AM
What is this Apple Update? Hard Disk Update...ver 1.0 McMasters Pro Tools TDM Systems (Mac) 1 06-30-2003 05:56 PM
