Solo Clear not working on S3
Hi All,
I've had the S3 for awhile now. Solo clear has never worked. I've been using ALT+ solo button to clear. I'm assuming it's a dedicated button since there's no way to assign it using Eucon software..... Solo Clear button does not flash when a solo(s) is engaged on a channel. Anyone having this issue with solo clear? TIA. Eucon 3.3.1 PT 11.3.2 Last edited by jmkeane; 10-04-2015 at 04:19 PM. Reason: clarification |
Re: Solo Clear not working on S3
Fixed. Replaced .XML file
What XML file did you clear? Today is my first day with a new S3 and I also noticed the Solo Clear is not functioning.
I found the XML files on AVIDs site. Here's the link for anyone else who has this problem:
http://avid.force.com/pkb/articles/d...est-S3-Appsets The Appsets are the XML files. |
Track Solo Not Working PT10 | georgepeter | macOS | 3 | 05-13-2016 11:22 AM |
Clear selected clips shortcut not working hd 10.3.2 | dgoodi22 | macOS | 7 | 02-08-2013 04:49 PM |
Protools 10: mute and solo aren't working. (Solo safe is not on any of the tracks.) | charlottewrinch | macOS | 2 | 04-14-2012 05:32 PM |
Clear Peak/Meter shortcut not working? | theblotted | macOS | 8 | 07-23-2011 02:46 AM |
Solo-Yellow, Solo Clear-Green | Imagine | ICON & C|24 | 1 | 05-14-2011 04:55 AM |
