DAE error #-7054 with PTLE 8 & Arturia Minimoog V 2
I updated Arturia's Minimoog from 1.6 to 2.0, and now when I try to instantiate it in PTLE 8.0cs2 I get this message:
The plug-in could not be made active because a DAE error was encountered (#-7054). Any ideas? Thanks! Bob K
Pro Tools Studio 2023 || M1 Max Mac Studio, 64 GB RAM || macOS Ventura 13.6.1 || Metric Halo ULN-8 mk4 |
Re: DAE error #17054 with PTLE 8 & Arturia Minimoog V 2
Bump.
Anybody using this VI successfully in PTLE 8?
I don´t know why but Arturia never worked on my System, while everything else does.
It´s not much help for now, but you should ask Arturia, since V2 is quite new. best
last: PT11.3.1 |
Re: DAE error #-7054 with PTLE 8 & Arturia Minimoog V 2
I've already submitted the question to Arturia tech support and also in their Minimoog tech issue forum.
I think this is old now, but if anyone else has this problem here is what to do.
-GO to your PT plug-ins folder (in your Digi application folder there is an alias to it). -check the Minimoog V version you have in there (i still had V1.6, even after installing the new MM package). -Remove old version from Plug-ins folder -re-install Minimoog V package. -You should now see the new 2.0 version in your plug-in folder, and the Minimog should now work in PT. joel
www.joelfountain.com |
Arturia 2.5 minimoog installer ????? | mafiacondon | Virtual Instruments | 0 | 10-05-2011 02:50 AM |
Arturia Minimoog V Plugin troubles | theworks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-24-2011 12:49 PM |
MIDI notes get stuck? Arturia Minimoog V | fishrivers | MIDI | 1 | 05-29-2006 11:40 AM |
Arturia Minimoog... opinions? | wedgewedge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-09-2006 08:56 AM |
Arturia Minimoog V Problems | riotbeats | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-27-2005 06:35 PM |
