Pro Tools takes forever to start up
Hi-
I am just setting up a G4 1.25 gig dual boot computer that I have installed Pro Tools 5.1.3on the OS 9.2.2 side. The problem is that when I start Pro Tools it takes a very long time to start up. The delay seems to be after DAE launches and all of the plug-ins have loaded. That is when it just sits forever before the probram is ready to run. I have tried increasing the memory to DAE and Pro Tools and it still does the same thing. My set up is the G4 1.25 gig computer w/1 gig of ram, Magma/Pro Tools 13 slot chassis with mix core, 5 mix farms, 2DSP farms and 2 Sample Cell TDM cards.There is an ATTO Express PCI Pro Dual Channel SCSI Card that has an external drive hooked up to it.There is also an Aurora Fuse card in it. This same setup worked flawlessly in my Quicksilver 733. Any thoughts on how to correct this would be greatly appreciated. Thanks Wayne |
Re: Pro Tools takes forever to start up
bump it up. Any ideas on this one?
We had somewhat of a similar problem. It would stall while loading the plugins. I researched the web and was advised to delete the protools and digidesign preferences. The files somehow got corupted. If you do this, when you start protools again, it will recreate those files. It worked for us.
do you have Sampeltank in your plugins folder. It gave me some problems once. get latest update
post on
www.soundmill.dk |
Just had to update and say thanks for the heads up. I forgot that I had originally installed with just a core card so when I added the chassis full of cards it took forever to start up. After removing the digi setup and pro tools prefs all is well again.
thanks to all again! Wayne |
6.7 and 10.3.5 with 101 items in my plug-in folder takes 1:10 to get to the workspace window.
My Mac boots in 1:00. (Journeling boot drive) |
yes.. I have to admit, this is a big pain in the arse. Sessions load up much slower also. My PT HD accel /dual 2 gig G5 takes twice as long to get me into protools as my MixPlus /800 G4.. What gives? Is it the ilok? If so, how about a firewire 800 ilok?
2009 Mac Pro Nehalem 2 X 2.26GHz Quad-Core Intel Xeon - OS 10.9.5 Mavericks - 128GB ram ProTools TDM HD6 - Magma Expansion Chasis - PT 10.3.8 and Avid I/O. ProTools 12.7.1.733 Macbook Pro 2.66GHz Intel Core 2 Duo OS 10.9.5 ProTools 12.7.1.733 Mbox2 PT 10.2 Scott Whittier Whittier Creative http://www.madmix.com/ www.voice123.com/scottwhittier |
If you want your sessions to load faster in OS X put the max RAM 2 GB. Since I did that it's a lot better. Also make sure you have lots of free space on your drive.; OS X takes 5 GB of Virtual Memory and when protttols is running you need at least 1 GB of real memory. Just use Activity monitor and you'll see how much OS X is a memory pig.
PT 10 takes forever to start up | DJYoutubeDJ | Pro Tools 10 | 3 | 06-28-2013 01:39 PM |
Pro Tools 11 takes forever to start? | hollywoodbeats | Pro Tools 11 | 6 | 06-25-2013 05:49 AM |
PT9 takes forever to start opening | Ryan Young | macOS | 2 | 12-27-2010 03:51 PM |
Pro Tools Takes Forever To Close Sessions | lenkarm | Pro Tools TDM Systems (Mac) | 0 | 08-27-2010 01:27 PM |
001 recording start takes forever | jtrolka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-29-2003 12:57 AM |
