  #41
Old 08-12-2015, 05:49 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Default Re: Alternate techniques for De-Essing
Another nice De-Essing alternative is to use a multiband compressor. Fabfilter MB sounds best to my ears. Alternatively McDsp A400 can also work ok.
Christian D Hagen | I7 Builds | PT/OS Compability Chart
  #42
Old 09-16-2015, 01:23 PM
AlexLakis AlexLakis is offline
Fabfilter was great when I was demoing it. Since then, I've moved back to Massey's De-Esser, and found the key to using it: The mix knob. I get just-as-good results now as with the Fabfilter.
Of course, manually picking out the esses in the edit window and applying your own trim gain reduction has its place too.
  #43
Old 02-07-2016, 10:23 AM
chrisoz1435 chrisoz1435 is offline
I've never been completely happy with any de-Esser. Like a few here, I manually adjust the clip gain and find it works well for me.
  #44
Old 03-09-2016, 04:01 AM
Captain Al Captain Al is offline
Automating the trim is one way, how about this variation
Duplicate the track, cut & drag every s to the duplicated track, dip the volume or roll off a freq to suit..
Easy to adjust any s then :)
It's an odd trick I hardly ever do but sometimes when the de-essor just won't cut it, it can help take a different approach, especially if the sibilance varies a lot.
  #45
Old 03-12-2016, 04:59 AM
EKmixmaster EKmixmaster is offline
Untill recently I've been using Waves RDeesser which is great and I can't see much reasons why to have that much headache drawing manually automation for every esss.
Anyway I must admit that there cases when de-esser isn't best solution cz it ruins vocal's top end frequencies - like for extremely compressed vocals or some vocalists whith too expresive sibilants (well THIS is the case when esses volume automation needed first!!!)
So in 99 of 100 I grab de-esser to fight with esss noise.
P.S.: lots of pro vocalists have amazing technique and control esses very good either so no de-essing needed.
  #46
Old 04-04-2016, 06:09 PM
larsongs larsongs is offline
What do you all recommend for 'K' sound?
  #47
Old 04-04-2016, 07:33 PM
amagras amagras is offline
I use fade-ins if they are at the beginning of the word
amagrasmusic.com
  #48
Old 03-01-2017, 11:13 AM
Ansleyarch Ansleyarch is offline
When we conversation about sibilance in relative to a vocal footage, we're mentioning chiefly to the 's' sounds; loud high incidence consonants shaped by the commotion as air whistles finished a singer's teeth.
Buy Dissertation Online
  #49
Old 03-01-2017, 08:20 PM
Muddy-T's Avatar
Muddy-T Muddy-T is offline
Well put! That is so true..! Not too shabby as first posts go.
And, may I add, what a great way to bump a year old thread..!
"Don't look; listen!"
At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6
At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1
  #50
Old 03-22-2017, 09:13 PM
critictalk critictalk is offline
Nova from Tokyo Dawn is also good at de esse, and it is free!
Sent from my SM-G5308W using Tapatalk
De-Essing......where in the chain? jlcnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 07-27-2013 08:45 AM
De-essing Notefarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-21-2004 09:34 AM
De-essing Vocals skylab001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-15-2004 01:11 PM
Hand de-essing tips please! Jules Tips & Tricks 21 04-02-2003 01:52 AM
De-essing With Digi???? sugarfuzz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-25-2002 11:17 AM
