Old 04-03-2001, 07:55 AM
Don Henry Don Henry is offline
Default NEW APPROACH TO VOICE- OVER TRACKS
I've used every trick in the book on male voice-over tracks to try to make them sound brilliant and ground-shaking. But I'm tired of using the same old techniques. Anyone with any fresh new tricks, new approaches? Thanks!
Old 04-03-2001, 09:05 AM
Bokir Bokir is offline
Default Re: NEW APPROACH TO VOICE- OVER TRACKS
How 'bout sharing some of that boring tricks?
I really interested to learn. Thanks.
Satrio Budiono
FourMix JFS
Mac Studio Max M2 (2023), 32GB RAM, Ventura 13.6.4, PT Ultimate 2023.12.1, Sonnet TB2 III-D, Avid HDX 2, Sync X, MTRX Studio, Trinnov D-Mon, JBL 708P, 705P & JBL 3635 (Atmos HE 7.1.4)
Old 04-03-2001, 09:25 AM
AdamFrick AdamFrick is offline
i've learned over time that the best way to get that close, big sound is to get the talent right up on the mic. that proximity effect is very hard to fake with eq and compression. other than that, i often use L1 as my compressor when i need a voice to pop out over a track, because its very clean and very easy to control - it always just seems faster than toying with makeup gains, thresholds, etc for every new spot.
hope that helps.
=adam=
Old 04-03-2001, 10:22 AM
dBHEAD dBHEAD is offline
If it's shorter than a few minutes, you might try this trick I just thought up a few weeks ago and used on a project yesterday.
If the audio can be chopped into segments of less than fifteen or twenty segments, take each segment, and use the time compressor/expander on it like this:
Do one TCEX where you've set the ratio ar .999:1 -- then take the same (original) segment and do a TCEX with the ratio of 1.001:1.
Put them in three different tracks. Nudge the original 1 ms for every two seconds of length; nudge the .999:1 TCEX 2 ms for every two seconds of length. Do not nudge the 1.001:1 TCEX at all. Then play.
Adjust the gain on both TCEX tracks until you have the sound you want. Yes, there is a phase shifting effect -- which is exactly the point. Used with subtlety, it can give you a deeper low end and more pristine high end. NOBODY who heard the project I did this with noticed a phase shift at all and several people commented that the voice-over sounded great.
Old 04-03-2001, 11:30 AM
DigiDawg DigiDawg is offline
DbHead,
The idea is intriguing. Are there any mono compatibility issues with this approach?
I work on a lot of radio projects, and I find that using MS on an announcer adds the necessary "distinct" sound without any mono problems.
Nothing worse thatn a client complaining that something they paid for doesn't sound the same on a bad radio speaker, etc.
-DigiDawg
Old 04-03-2001, 07:06 PM
stuart newman stuart newman is offline
This technique that you thought up dbHead is VERY similar to a Bob Clearmountain technique, even Ricky Martin's producers picked up on the technique for "Livin' la Vida', they created two new tracks, copied the same region, panned hard left and right, pitched one up 12cents, pitched one down 12 cents, preceeded the lower pitched track 18ms, proceeded higher pitched track 18ms. Found a good mix. Voila.
Old 04-04-2001, 03:00 AM
Here's one thing that I recently tried: I tracked the VO using two mikes at the same time, using a U87 and a Solidtube. Each mike went into a separate track. The signals were totally separate of each other to avoid phase problems. Once recorded, I applied a lowpass filter on the Solidtube track cutting everything above 400Hz. For the U87 track, i ran it thru a highpass filter cutting everything below 400Hz. Next was to delay the Solidtube track for a ms. After this, apply your usual compression, dynamics, etc. to your specific taste. It's good for certain applications. It sounds different. The best part about it... no audible phasing problems.
Old 04-05-2001, 12:51 AM
DigiDawg:
Actually, the VO was mono. I did not pitch the TCEX tracks to either side -- everything was centered.
I wonder what it would sound like with both the technique I described PLUS M/S decoding?!
Hmmm. I'll have to give that one a shot.
Voice tracks at different volumes THStudios Pro Tools 10 5 01-11-2012 12:22 PM
Voice and guitar tracks. supergirl36 Pro Tools 9 2 10-08-2011 12:59 PM
need to record guit + voice live - what approach? Joseph Anderson Pro Tools TDM Systems (Mac) 5 09-24-2003 08:41 AM
Editing tom tracks - your approach? Emerson Scott 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 02-18-2003 10:32 AM
Voice weirdness: tracks play wrong voice - any suggestions? citysoundman Pro Tools TDM Systems (Mac) 17 10-03-2002 01:45 PM
