CD not closing session?
I am aware that there have been other posts concerning this issue, but I'll start a new one hoping to get some feedback, especially from digidesign. I have 4 different CD recorders, all compatible with Masterlist CD, and have always been able to use MLCD without any problems, up until version 2.1. I am currently using version 2.2 I have used MLCD since version 1.0 and was probably the first person to buy it. Since that time I have run into several problems, the latest of which follows:
When I burn a CD on my Plextor R8220T, MLCD will not close the session. I am aware that there is no option in MLCD to leave the session open in the first place, but for some reason this is happening. If I take the same material on the same computer and use my Sony CDW-900E to burn this disc, then everything works correctly and the session is closed. I have tried different types of media to see if this has made a difference, but still get the same results. I will do the same test on 2 other burners, but wanted to post what I know now and hope to get some feedback. I'll let everyone know the results. Any ideas? [This message has been edited by blairl (edited April 19, 2000).] |
Re: CD not closing session?
I would also appreciate some feedback from Digi on this. I've had the same problem with a Plextor 8220Te.
I tried writing an image file, but that doesn't work either. I doubt whether the cables are at fault as Toast and Jam have no troubles closing discs with this drive, and it would be a bit too much of a coincidence for so many people to be reporting this behaviour. There is no firmware upgrade available for the 8220 for Macs at the moment, so there's no way I can check if this might work. Anyone have a definitive answer? Marcus |
OK I did some more tests:
Blair,
Don't know the answer myself, but I'll pass your question, data, and this url on to the product manager and engineers for MLCD. Thanks. ------------------ Bruce Paine eMarketing
Administrator Avid Pro Audio Community |
PT 11.02 freezing after closing a session and opening new session | asaffulks | Pro Tools HDX & HD Native Systems (Win) | 2 | 12-17-2013 01:49 PM |
Session layout not being remembered after closing/reopening a session/Pro Tools! | DJ Hellfire | Pro Tools 10 | 1 | 12-23-2011 12:05 AM |
7.3 closing session ?? | jeam25 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-08-2006 08:45 AM |
PT 7.1 "Closing Session" dialog | JKD99 | Post - Surround - Video | 3 | 09-10-2006 03:18 PM |
Closing a session? | mattshort | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-23-2005 11:58 AM |
