6/8 time click all wonky?
Hi folks...
just working on a song at 6/8 time 90bpm, the bars display is accurate, but when I enable the click, it's on some wierd triplet off beat thing? why and how do I solve that? thanks!
cheers, rich |
Re: 6/8 time click all wonky?
What are your click settings set to?
Does it play normally in 4/4? Which version of Pro Tools and OS version are you on? |
I'm on PT HD1 7.4 and Mac OSX 10.4.9
The click is perfect in 4/4 time, but I'm not sure how to switch it from quater notes to eigths. I think that's the problem here, it's playing 1/4 on a 6/8meter...and I would prefer it to play eighth notes. I went to click/countoff... window, and there's no option for changing the note base for the click. Can't find anything in the click plugin either... it's probably something really simple that I'm missing
cheers, rich |
Hey Rich,
In your Edit window, press the + sign next to "Meter" in the upper left corner.It should display a "meter change" pop-up window. The last (4th) box down is CLICK: If you click*hold on the note figure, it'll allow you to change the resolution of the click. (If the meter reads 6/8, and you select 8th note resolution, it should play an 8th note click in 6/8 time.) Is this what you're wanting to do?? Hope so...
-C' ya' Rick MacPro 7,1; 16 core OSX 13.5.2 PT 2023.9; Eucon 2023.6 Dock/S1/2x iPad |
cheers, rich |
glad it's working for ya!
pro-tools acting wonky.. so is my 003 | goggs33 | macOS | 0 | 10-09-2011 04:24 AM |
non wonky sync with logic? | James Drake | Pro Tools TDM Systems (Mac) | 15 | 03-11-2011 02:08 AM |
Selector & Trimmer has gone wonky | DrumEatDrum | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-03-2010 04:13 PM |
time shift plugins acting wonky | studiojb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-16-2007 04:32 PM |
Output levels gone wonky! | Tim R. | Pro Tools TDM Systems (Mac) | 6 | 10-26-2005 08:08 PM |
