Old 06-05-2020, 01:28 PM
KingTor KingTor is offline
Default Re: What are people's experiences with Auto-Align-Post?
Copy that, Marti. I wish we had your budgets and subsequent plugin budget here. I've been getting by for 25 years without it, so a few more months isn't going to end my career.
smart phone my ass
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
Old 06-05-2020, 02:15 PM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Autoalign Post changed the way we edit and mix dialogs today.
It also saves time when trying to match EQ as there are no more coloration caused by the phasing issues.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 06-05-2020, 04:25 PM
dr sound's Avatar
dr sound dr sound is offline
I understand. It does allow one to get better quality Dialog, have to do less ADR recording and allows you to get a better, faster mix.For me it paid for itself after 1 episode of a TV mix. When clients compliment what better sounding the dialog is then it becomes very obvious of what I was missing. Start saving your money
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 06-05-2020, 10:50 PM
Ayush Ahuja Ayush Ahuja is offline
Marti, how do you and fellow mixers EQ dialog on a session with Boom and Lav auto-aligned? Do you EQ the clips individually and then touch up the overall sound on the DX Master/Reassign bus? With auto-align and more and more multi-cam shoots I'm finding many of our sessions are boom and lav together.
PT Ultimate 2023.12, MacStudio M1 Ultra 64GB RAM OSX 13.1, Avid MTRX Studio, Avid S1/Dock + VideoSync 5, MacMini 3.2GHz i7 64GB RAM OSX 10.13.1
Old 06-05-2020, 11:08 PM
smurfyou smurfyou is offline
I think that's the key to why it's getting so much use now. All of these multi cam shoots kill the boom. It becomes a room mic to liven up the lavs. I've noticed it really comes in handy with rustly lavs, you can cut tight on the lines and leave the boom playing for the air and movements so it still sounds natural.
I really dislike having to cut multiple mics in but this beats the pants off aligning manually.
~Will
  #16
Old 06-06-2020, 03:50 AM
Branko's Avatar
Branko Branko is offline
First, I would use both sources (boom + lav) only in cases where I cannot get the whole information I need from one. That means one of those mics will always be the main one and the other will be added to fill in. I always EQ on channels, never on DX master bus, so I'll EQ the main mic to get what I want from it, and then blend in another one to add, as smurfyou said, room, brightness, or whatever else was missing.
Imo, the biggest change this plugin brought was not for DX editors. You still have to do most of the editing operations that require other tools. Previously, one would never spend hours trying to align clips perfectly, because there was a limit of how much you can achieve with standard tools - cut, move, phase invert. The real revolution is in the way we mix DX now - the freedom to add up sources without watching for phase cancellations is a completely new experience.
Branko Neskov c.a.s.
www.loudness-films.pt
  #17
Old 06-06-2020, 05:39 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Originally Posted by Pete Gates View Post
Hey Tor,
Yes, I'm using it it phase-align different mic channels from location recordings, not for aligning ADR. I think it's a brilliant (and brilliantly simple to use) bit of software, just noticing that it's not always 100% reliable and wanted to canvas opinion on that.
Pete
Ive had very good results with AAP.
When static doesn't work well, even though there is no movement, I go dynamic, and get amazing results.
The other, is I get in such a hurry, I forget to hit analyze before render.
IMDB
  #18
Old 06-07-2020, 12:50 AM
I've been using dynamic all the time.
What I have found useful is to have an autmomixed Lav track from the sound mixer - which cuts to the speaking actors Lav (if setup correctly). I use this as my phase reference as it has less movement than the boom. I can correct individual lines if required later, for head turns or scenes with much more movement and dialog overlaps.
  #19
Old 06-07-2020, 04:51 AM
Pete Gates Pete Gates is offline
Hey Ayush,
I'm curious about what you're doing? You've got a mixed lav track and you say you're using it as a reference... for what? Are you doing it the other way round and aligning the boom to the lav? Or is it something else?
Cheers,
Pete
  #20
Old 06-07-2020, 02:46 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Hi Pete! Hi everyone.
I just finished using it on a feature film and I'm very pleasantly impressed! I kept the settings to "create individual files" and "clip by clip" so it can preserve my edits as well as my clip gain automation.
I had already gone through and done a full edit and pre-mix pass on all booms and all lavs, and exported a mono stem of each (mono boom, mono lav).
Then I saw this thread.
So, previously, during the sections where I wished I could use both, and hand-sunc my boom to match my lav, I was really frustrated with the varying delay, phasing, and phase cancellation.
NOW, I use my (muted) lav print as my key input across the board so any boom clip I wanted to double up with my lav, I'd select, preview, render (in dynamic mode).
It's honestly been really easy and helpful; haven't had a single issue yet. Well worth buying it, even though I was able to process my entire feature in about 30 minutes while in my trial. This helped so much with adding space and brightness to some muddled and lifeless lav tracks.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
HTML code is On
Auto Align Post at The Dub Stage dr sound Post - Surround - Video 4 08-26-2018 01:07 AM
WTB Sound Radix Auto Align Cryos Buy & Sell 0 02-21-2018 06:29 PM
FS: Sound Radix Auto Align StymphalianProductions Buy & Sell 7 09-01-2017 12:59 AM
WTB: Sound Radix Auto Align TrentWilliams Buy & Sell 0 12-22-2015 03:38 PM
Anyone had Hard-disc recorder experiences in Post Production tom.joyce Post - Surround - Video 4 08-21-2007 06:32 AM
