Old 12-30-2000, 04:01 PM
bigfrog bigfrog is offline
Default New hard disk in G4 - HELP!
I'm having trouble with a new Fujitsu 10GB ATA 66 drive for my G4. I installed it as the second (slave) ATA drive. I followed the Apple installation instructions - the system booted up & recognised it. I used Drive Setup to initialise it - it initialised (in a few seconds). I moved some audio files to it - they played back fine. Then I shut down.
The sytem now throws up errors when I try to re-boot. "illegal instruction" followed by "unimplemented trap" forcing me to boot with extensions off.
I have unplugged the new drive for now, but I'm stuck!
HELP!!!
[This message has been edited by bigfrog (edited December 30, 2000).]
Old 12-31-2000, 10:45 AM
Gulliver Gulliver is offline
Default Re: New hard disk in G4 - HELP!
Do you have Norton Disk Doctor, or any other type of disc scanning software? If so, turn those extensions off, or remove it from your system.
Old 12-31-2000, 01:53 PM
Hi Gulliver,
Thanks for the advice. I don't have Norton, but I will have a look through the extensions to see if anything looks like a culprit.
Happy New Year!
BF
Old 12-31-2000, 11:07 PM
sv_guy sv_guy is offline
Maybe you didn't set up those jumper pins on drive in the correct way or maybe the ribbon cable is plugged in the wrong drive. The start up drive has to be on the end of the cable and the slave drive has to be in the middle with the cpu at the other end.
Old 01-01-2001, 04:51 AM
…or maybe Apple don’t mean it when they say “If there is a factory-installed ATA drive, it is configured as the primary drive”. For PRIMARY read ONLY!
Checked out jumper configs on Western Digital’s site, set the main HD as primary, double-checked Fujitsu jumpers (they were OK) fired up and got Error Type 10, then Unimplemented Trap.
Checked through Extensions – nothing looks suspicious, but I’m not an Apple expert.
Still puzzled…
Old 01-01-2001, 10:48 AM
I've given up on this one! Agrrrh.....!
Old 01-02-2001, 09:52 AM
dabu2012 dabu2012 is offline
http://www.xlr8yourmac.com/IDE.html#drives
This is a great site for mac help of all kinds.
dave
Old 01-02-2001, 02:54 PM
So it is!
Thanks
ssd hard disk or classic hard disk to install pt9hd? hart07 Pro Tools HDX & HD Native Systems (Win) 4 10-21-2012 07:13 PM
Which hard disk should I put it on? [email protected] 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-24-2009 05:41 PM
HELP FOR HARD DISK!!!! stefano manelfi Pro Tools TDM Systems (Mac) 7 10-14-2005 06:54 PM
Help! Hard Disk attached to Disk I/O will not mount. di.vo Pro Tools TDM Systems (Mac) 1 04-29-2001 10:32 AM
Parallel hard disk from difference disk i/o ends? alfred Pro Tools TDM Systems (Mac) 1 11-03-1999 12:00 AM
