Volume for Mastering.
I hope some of you folks can give me some suggestions - thanks.
While mastering, I am trying to match the volume of a reference track from a CD, but after I bounce down to CD and compare with the reference, my track is much louder. Here is what I am doing: * After I import the track (AIFF) , I compare the volume of my track and I notice they both hit the same level on the faders. * My track sounds louder and I solve this by using a Sonnox Limiter plugin to reduce the volume. * After I bounce my track and burn to CD (itunes) and listen to it on my stereo system my track is much louder. Is there something I am not doing right while importing the reference track from the CD? Should I think about changing the import encoder on itunes from AAC to WAV or something else? Is there any reason why I should not use itunes & use another program? In terms of audio quality itunes actually seems ok. It's just this volume issue that I need to overcome.... Thanks to all you PT users. |
Re: Volume for Mastering.
Why not Bounce your mix without anything on the master fader and then import the mix into a mastering session toghether with your reference track. There you can fine tune, EQ and set the volume, and try to make your mix have the same feel as your reference. Very much used technique. And the result should be that they come out the same on CD.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Make sure you use an RMS meter along with your peak meter.
MacBook Pro 2.2 GHz Core i7 4GB RAM 10.8.5, PT 10.3.4, Waves v9.1, Duet 2 redtuxedo.com milkmoneyconsulting.com mindexpansiontechnology.com |
http://download.cnet.com/Burn/3000-2...ml?tag=mncol;1 best
last: PT11.3.1 |
Thanks man. Do you know of any free or cheap RMS meter plugins I can download?
Best, KNM. |
also BluecatAudio Freepack is also very nice. http://www.bluecataudio.com/Products..._FreewarePack/ AND DON`T FORGET: you have TL MasterMeter for free in PT8, this also a great meter
last: PT11.3.1 |
Just reading this and found interesting, as have had similar challenges before. So what exactly does the RMS meter do and how does it work to solve the problem?
thanks
TDub Digi002 R with Command 8 - PTLE 8.03 Intel Quad Q9550 Asus P5Q Pro Win XP 4GB |
RMS (root mean square) shows an average level instead of instantaneous peak values. You could have a single peak around -0.1 dBFS but your average level could be relatively low.
Volume in regards to mastering | Matt Subbz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 08-06-2010 02:22 PM |
Mastering/Maximum volume | sunnyside | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-03-2008 04:38 PM |
Mastering: Commercial Volume | nero120 | Tips & Tricks | 16 | 01-23-2007 09:51 AM |
Mastering volume | chaplain64 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-04-2005 06:33 AM |
How do you get the right volume when mastering? | DMP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-03-2002 07:50 AM |
