Old 09-04-2017, 03:25 PM
Nathan W. Nathan W. is offline
Default iMac Pro Xeon vs. iMac i7
Has anyone run tests to see how much faster a Xeon machine is vs. a standard iMac i7 at certain tasks? In particular, I'm interesting to see if any RX6 advanced features would process audio faster and by how much. Better to buy an iMac or iMac Pro?
Old 09-04-2017, 06:06 PM
reichman's Avatar
reichman reichman is offline
Default Re: iMac Pro Xeon vs. iMac i7
I can't comment directly on this topic, but you could do some tests to see how well RX6 is utilizing multiple cores by watching Activity Monitor. I'm pretty sure it runs most processes on one core. Cross-reference whatever you discover with the single-core performance scores on Geekbench. You would have to extrapolate from other Xeon tests because there is zero data available on the iMac Pro, but possibly some data on similar Xeon chips running on other systems...
FWIW, RX6 is fast on the current crop of Mac Pros. But that said, the current iMacs are famous for having higher single-core scores. In all likelihood, the 6-core iMac Pro will be outfitted with a chip that has higher single and multi-core scores.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 09-05-2017, 05:07 AM
tom_lowe tom_lowe is offline
iMac Pro will start at 8 cores, then 10 and 18. The clock speed of the 18 core looks like it'll be significantly slower than the 8 core.
Old 09-05-2017, 06:34 AM
quadraphonics quadraphonics is offline
Would it be fair then to say that Pro Tools and RX and such don't really benefit from the larger multi-core systems as much as higher single core speeds?
I was thinking of jumping ship to something like the newer i7 or Ryzen processors, but if Pro Tools doesn't really use the multi-core processors as efficiently as , say, a 3d rendering software, maybe i need to rethink what I was going to purchase.
Thanks,
Randall
Old 09-05-2017, 07:36 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
My understanding is that 6 cores at the highest FPU calculation speed is the best real time performance.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 09-05-2017, 05:18 PM
reichman's Avatar
Not at all. In fact, totally the opposite. DAWs spread the tracks out among cores and are often some of the best utilizers of multiple cores (parallel processing). I thought the OP was referring to offline RX performance, which is single-core. Online, multiple-plug-in performance is multi-core. I think it was Bobby Lombardi who talked about the fact that an individual track in Pro Tools has to exist on one core, so if you have just a few tracks with a zillion plug-ins on each track, high clock speed per core will help you (you'll get a CPU overage if one track maxes out one core, regardless of numbers of cores not used). But if you have a zillion tracks with just a few plug-ins on each track, Pro Tools will balance the track load across all available cores.
Nathaniel Reichman
Old 09-05-2017, 05:25 PM
Bobby Lombardi is who told me that six cores are optimal!
Interview
HTML code is On
Tranferring Protools 10 from old iMac to new IMac JuergenTilak Pro Tools 10 3 07-31-2012 08:48 AM
Imac and ext HD Bruno5150 macOS 9 11-30-2011 05:24 PM
2010 iMac 27" i7 quad VS 2009 MacPro 2.66 Xeon sweetness 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-27-2010 11:01 PM
24in iMac or 21.5 iMac??? Help the blast 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-30-2010 05:19 PM
sync iMac with 003 and iMac with Mbox2? Jussi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-09-2009 03:24 PM
