PT 10.3.8 crashing on DAE Objects on startup
I’m having a serious problem with a very old system. Mac OS 10.8.5, Pro Tools 10.3.10, 192 interface. It was mostly stable until a few days ago. Now it won’t even start— it keeps crashing on “DAE objects created”. Holding “n” during start up doesn’t help. I’ve already done a complete re-install, which didn’t help. Any suggestions would be greatly appreciated.
Re: PT 10.3.8 crashing on DAE Objects on startup
You don't have a backup? I would suggest a full fomat and reinstall of OS and PT. Be shure to do the recommended optimizations: Computer Optimization Guides (Mac and Windows).
I never trusted the "progress info" on the PT startup screen to tell me anything about what might be a cause of problems. I suspect that info to often say what part of the process has been completed rather than what's loading now. |
More info plz
Hd card type, mac spec, other core audio drivers You get it! Thx
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
So doing a full re-install rather than just a “safe” re-install solved the start up issue and everything seems to be working fine, with one exception. Now the C|24 is offline, and it doesn’t show up when I try to set it up in the peripherals menu. Nothing has changed with the hardware or network settings so I’m at a loss as to how to get PT to recognize the C|24 again.
No Eucon installed correct?
C|24 direct to Mac Port #1? Rescan from Peripherals>Ethernet for both ports (Eucon box not checked) if that won't show the C|24 the reseat the cat 5 1st, reverse the cable if it's the digital-cable Good luck
Crashing on startup with 10.14.5 | hellatall | Pro Tools 2019 | 14 | 07-14-2019 04:28 PM |
pt 11 crashing on startup | lucidlife | macOS | 6 | 01-03-2015 09:41 PM |
PT 9.0.5 Crashing on startup!! | eanderso22304 | macOS | 3 | 10-05-2011 11:31 PM |
LE 8.0 crashing on startup | jbeband | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-23-2008 11:00 AM |
PT LE Crashing on Startup | beggehorn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-18-2006 09:18 AM |
