Old 03-12-2000, 01:13 AM
riorecords riorecords is offline
Default anyone using the system drive and storage audio drive in the same SCSI chain?
My mac(PPC G3-333mhz) came with an internal UW system drive plugged to the 68 pin internal port on the SCSI atto xpress single-ended PCI-PSC card. Will 001 work if I add another SCSI drive in the same chain bus internaly? Is any body using this configuration? because I don't know yet nobody with this kind setup.Or the best option is to go to an ATA/Ide drive connected to the port in the logic board? The ribbon of the UW drive has already the two 68 pin connector to add more devices to the chain and my unit have still two mor bay internally.
Ricardo
Ricardo
Old 03-12-2000, 05:36 PM
E. D. Cooper E. D. Cooper is offline
Default Re: anyone using the system drive and storage audio drive in the same SCSI chain?
Your proposed routing should be no problem. I use the same disk, divided into partitions for applications, documents and audio with no problem.
Old 03-15-2000, 11:09 PM
thaks to all for your answers. I took a desition before yours back and I'd like to share with anybody there with the same matter:
I search for the best driver performance ata/ide internal and ohh!!god; I bought the Maxtor DMA/66,72k rpm and easily installed and work just PERFECT, faster than the "SCSI drive"? and than any other drive manufacter, yes!!! faster than any others,like you hear!! and so quite and smooth.It was tested againts other drivers and the results was just better. Get info at www.yourapple.com and see by yourself.
Ricardo
Ricardo
No Audio, But Just Samples. System Drive Or Seperate Drive. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-10-2010 03:47 PM
USB Flash Drive for Audio Storage Rainyone Storage Subsystems 4 01-06-2008 08:30 AM
scsi ultra160 disk for system drive and audio drive jazzle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-23-2001 06:54 AM
After Hard Drive Crash Mac won't boot with defective HD in SCSI Chain Chris Pro Tools TDM Systems (Mac) 1 11-28-2001 01:06 PM
Boot Drive/Audio drive -SCSI? JimiTM Storage Subsystems 2 08-09-2000 12:04 AM
