  #21
Old 12-03-2023, 12:01 PM
t-sun t-sun is offline
Default Re: No sound on 002R units
Originally Posted by Darryl Ramm View Post
Sounds like you've done some good troubleshooting.
I would still test with signal gen, confirm you have a high level output at the further TRS plug on the output cable with a multimeter and use that to probe the line inputs.
I would still try to think through any common things here, whether they are as simple as sharing a potential broken audio cable or anything else you might be doing.
I would confirm that optical ADAT and S/PDIF coaxial input(s) are dead as well. Making sure you are feeding them at the correct sample rate, and clocking from the digital input.
Especially if the analog inputs only are faulty, you might want to poke around the 002 internals, starting with the power supply voltages and distribution to the analog inputs.
I have tried with multiple 1/4" cables, I have checked the cables with other equipment to make sure they're outputting a signal. I have no way of testing the ADAT or SPDIF connections other than to plug the other 002R into the ADAT I/O, which obviously wouldn't really help if neither are working.
As you said, these are museum pieces, and poking around in there with my multimeter isn't really worth the time because of how cheap they are. It does seem like a shame, but if I can't figure out what's going on then I'll have to just dump them.
Seamless change of hardware (sound units) ha2dorff macOS 4 09-13-2012 02:16 PM
Sound quits on 002R JustinAiken 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-06-2009 09:14 AM
setting up 2 CM Labs Motormix units with 002R help. recordingguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-11-2008 07:25 PM
002r not in Sound Preferences audiowiz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-11-2006 08:47 AM
002r for sound 6figgas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-09-2006 03:27 PM
