Old 04-28-2023, 05:04 AM
noiseboyuk noiseboyuk is offline
Default Our old friend -9173
I've never really suffered much from the much celebrated "Pro Tools ran out of CPU power. Try de-activating or removing Native plugins (AAE -9173)", but on a current show running 2023.3 I'm getting it a lot. It is a slightly different template to my usual, lots of instances of Sonnox Limiter v2, but nothing seems particularly unusual otherwise. CPU levels are low, sub 10% all round, and when it stutters and spikes the Total turns red even though it's still showing a low level.
Here's why I'm posting it though. If I close and restart Pro Tools, the problem vanishes. It seems oddly specific to a first launch after the rig powers up. I can't remember others reporting anything as odd as that.
One other curiosity - often the Clip Effects is sometimes unresponsive on a first launch too. No button does anything, even though it's not greyed out. On a PT restart, everything is normal once more.
Anyone got any theories as to what might be happening? The fact it always seems clean after a restart makes bug-tracking a bit tricky. I'm guessing a reinstall of PT might be on the cards - whenever I do this I uninstall the previous version, restart, install, restart. But I don't trash prefs, so I'm expecting that might be the next thing to try.
Win10 Pro, 2023.3. RME Babyface (buffer 512). Disk Cache on, fully green.
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 04-28-2023, 05:32 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Default Re: Our old friend -9173
I maybe be wrong but the -9173 error probably dates from DAE, the predecessor to AAE. Restarting Pro Tools will restart the 'Avid Audio Engine'.
You can probably still restart AAE by changing the buffer size, mid Session.
All plugins will interface with the AAE and cause errors. This is certainly a plugin/AAE/CPU error.
https://avid.secure.force.com/pkb/ar...Tools-AAE-9173
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 04-28-2023, 11:00 AM
mandal mandal is offline
Upgrade to Win11 ?
Microsoft Windows 11 Home 64-bit OEM DVD
Avid OMNI PCIe
Pro Tools Ultimate 2023.12
CPU: Intel Core i9-10980XE
Motherboard: Gigabyte X299X AORUS MASTER E-ATX
RAM: 64 GB Crucial Ballistix Sport LT DDR4
Screen card: MSI GeForce GTX 1660 VENTUS XS OC
Old 04-29-2023, 12:39 AM
Stephen
Thanks Steven - whenever I've tried changing buffer size or sample rate with PT running everything has gone to hell, so I've always taken to closing PT and doing it within the RME app.
Now I come to think of it - and this is a vague woolly thought - the first time I launch PT, it seems to make a real meal of things. It seems to take longer to open than normal, things appear more slowly as if everything is this awful effort. On subsequent restarts things are much more snappy.
mandal - win11... really? win10 is a fully supported OS, I've not heard of any compatibility issues only affecting win10. Or did I miss something?
Guy Rowland
Old 04-29-2023, 01:47 AM
Ben Jenssen's Avatar
Here's a recent duc post with the similar symptoms:
3 different systems crash during 1st session of the day
I see this all the time. After quit and relaunch of PT, the launch, session loading, everything seems to be faster than the first launch. I think this is new with native 2023.3. I've been thinking it's just a matter of data being sorted and available from RAM a bit more quickly because it is already there.
I think he was just trying to be funny.
Old 04-29-2023, 05:21 AM
This reboot/reset of the AAE will only work with changing the buffer size without closing the Session. The natural choice to tax the system less would be in increase the buffer size, say the next one or two higher. For example, if you are happy editing and mixing at 256 then try switching to 512 or 1024. If you are tracking then you will have you check the headphones/monitoring isn't too latent to use.
Other changes then Pro Tools will likely insist on saving and closing the Session itself to make the change.
Sample rate is dependent on the current Session file. Pro Tools will complain if the clock rate it detects hasn't been switched accordingly to match this file e.g. 44.1. or 48 KHz.
Stephen
Old 04-29-2023, 06:30 AM
Thanks to you both - Ben, that other thread is even more bizarre, in that it happens even if the machines are left on overnight? Who can explain that?
Stephen, I'm on 256, but my gut tells me this isn't the issue as the CPU never moves much above 10% even as it stalls. Still it's worth a try.
I might try going back to 2022.12 actually. It felt better all round, 2023.3 seems to be one of the bad releases with multiple issues. Sadly my support plan has expired, so that's the last update I'll get for a while. 2022.12 worked very well for me, so that's okay - I have elastique audio AAX as a permanent license so I won't miss that functionality. I won't update the plan just to get another slightly more recent working version as long as 2022.12 behaves as it did.
Guy Rowland
9173, 9173, 9173... Hellooooo Rectifried Pro Tools 12 2 04-19-2018 12:50 AM
48k is my friend DC-Choppah Pro Tools M-Powered (Win) 13 10-11-2010 05:48 PM
help a friend T money778 General Discussion 4 03-22-2010 09:36 AM
Who can help to my friend? tamasdragon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-23-2009 09:55 AM
For a friend's 002 Scott Goldberg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-25-2005 04:36 AM
