Old 01-26-2023, 04:38 PM
Miron02 Miron02 is offline
Default Midi Export Timing Issue
Hey Everyone,
This is my first post, so I apologize if this is the inappropriate place for this question. My issue is this:
I have a large session (13 songs with different tempos) and 2 midi tracks. I have rendered all virtual instruments to audio files and exported them to a new (cleaner) session, I plan on using live. Since audio is printed, the tempo for all audio files is where it should be.
The problem is, is that when I export the 2 midi files and import them into that new (cleaner) session, the midi tracks are off. Is there a way I can "print" the 2 midi tracks or export/import without it changing tempo/throwing everything off?
On the new (cleaner) session, I do not need to follow a timeline or care at all about real-time tempos as everything is basically printed (including click track). I also, want to move songs around from time to time.
Thanks in advance!
Midi Timing Issue lachlan Pro Tools 11 6 07-24-2015 12:53 AM
MIDI Timing Issue Alexmc1988 Pro Tools 10 6 04-22-2014 03:45 PM
Sync issue, pro tools MIDI and MIDI controller, timing issue Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-29-2011 07:57 AM
MIDI timing issue PT9? antidogmatiq Pro Tools 9 3 04-22-2011 09:16 AM
PRO TOOLS EXPORT TO CUBASE IMPORT TIMING ISSUE Jim Casey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 34 07-25-2007 05:22 AM
