Old 08-27-2022, 10:27 AM
foret_sombre foret_sombre is offline
Default Avid Video Engine in 22.7 "not installed"
Hello everyone,
I'm on Windows 10 and have a mensual subscription for Pro Tools Studio 22.7.
I have this popup which says "The Avid Video Engine is not installed" whenever I try activating it from the engine menu, deactivated by default on launch.
This problem doesn't go away after :
  • full uninstalling, reboot and re-installing
  • full uninstalling, reboot, deleting previous register entries related to the Avid Video Engine (I had the PT 12 HD crack installed for years before buying for 22.7, and apparently it let files in Public > Documents), reboot, re-installing
I read somewhere that I had to create a register entry for the right version of PT but I don't know how to do this and even if it's the right thing to do.
Thanks for your help !
Old 08-27-2022, 02:58 PM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Avid Video Engine in 22.7 "not installed"
Here is a good article on how to install the AVE on Windows.
Will
System Details
Old 08-28-2022, 01:26 AM
Hi junkgear,
I tried that too and it doesn't work. The AVE isn't even showing in the Utilities folder or in the Programs list.
Windows 10 Professionnel
Processeur Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz, 3192*MHz, 6 cœur(s), 12 processeur(s) logique(s)
Komplete Audio 6
Pro Tools Studio 2022.7
Old 09-12-2022, 11:39 PM
Damon_Ellis99 Damon_Ellis99 is offline
Originally Posted by foret_sombre View Post
Hi junkgear,
I have been having the EXACT SAME issue !!!!!
AVID charge you £30 to have a phone call with them and it is just ONE !!! I have paid £250 for what????!!!
I have not been able to do any music for over a week because of this hahaha
Old 10-07-2022, 09:39 AM
nicolasvr nicolasvr is offline
Having the same problem here since i upgraded to 2022.9
The AVE doesn't appear in the utilities even after full re-install.
Did any of you guys got a reply from Avid about the issue?
Dell Inspiron 17-7778 laptop
2.6 GHz Intel Core i7-6500U
16GB RAM - Win 10 Pro
Pro Tools 2022.9
Old 10-08-2022, 03:43 PM
dstone dstone is offline
Avid normally stores a lot of it's information in the following location:
C:\Users\Public\Public Documents
I recently installed Pro Tools Intro so I can start to get an idea on how to use it. When I looked into the above directory I saw an entry for the Avid Video Engine. The video engine isn't installed with Pro Tools Intro, but the folder is there.
See if the AVE is somewhere in that folder first.
Old 10-08-2022, 04:00 PM
And just for grins I decided to look into the registry. The version number for the Avid Video Engine was marked as 22.8.0, and not 22.9.0.
If you are comfortable with the following, make a reg.txt file in notepad and add the following:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Avid Technology\Avid Video Engine]
[HKEY_LOCAL_MACHINE\SOFTWARE\Avid Technology\Avid Video Engine\22.9.0]
"DataLocation"="C:\\Users\\Public\\Documents\\ Avid Video Engine"
For some reason, a space is being inserted in the DataLocation line just before Avid Video Engine. Delete the space before saving.
Save the file, and then rename the file to reg.reg. Double-click on the file and it will add that key to the registry. Restart your system. That may get the AVE to work. Or not. I have no way to test that here.
NOTE: I had to update the key entries to get them to install correctly.
Old 10-20-2022, 01:36 AM
Ooh okey, didn't notice about the space issue. I had tried this already in the registry editor but it didn't work.
Now the video engine fires up again. About time.. Thanks for the tip
Pro Tools 2022.9
Old 10-20-2022, 05:42 PM
I figured out that this was most likely the culprit. If you're on 22.7.0 or some other version, change the 22.9.0 to your current version (e.g. 22.7.0) and add that to the registry.
Old 12-28-2023, 07:31 AM
Kaianglow Kaianglow is offline
Great, I was looking for that topic. Good tips! I often have questions when installing software because I'm not very proficient in it. At work, while working on advertising projects, we often turn to https://www.2orange.nl/narrowcasting/. They specialize in narrowcasting solutions for similar projects. This service deals with both software and hardware, so we frequently rely on them.
"The avid video engine was unable to stop" error hbadger30 Pro Tools HDX & HD Native Systems (Mac) 20 10-01-2019 03:51 AM
"Timeout while trying to connect to the Avid Video Engine" jsummerskvi Pro Tools 12 4 11-28-2017 07:27 AM
"Connecting to Avid Video Engine" postmike Pro Tools 12 1 12-15-2015 06:13 PM
Can't import video "Avid engine not installed"??? garnoil Post - Surround - Video 9 10-08-2012 04:45 PM
"Avid Video Engine Not Installed" trondned Post - Surround - Video 9 09-17-2009 02:43 PM
