Can't hear MIDI
Hi everyone,
Sorry if this is a very basic inquiry but I'm new to Pro tools (and DAWs in general) and I'm still working things out...plus I'm a bit of a tech dinosaur Sooo I'm trying to listen to a piece MIDI I just recorded, but with no success. I imagine I need to have a plug-in (e.g. xPand2) to select an instrument with which to play the MIDI, but there are no INSERTS in MIDI tracks... Suggestions? Many thanks!
Virginia, Tech dinosaur Lenovo Thinkpad Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz 2.11 GHz 8 GB RAM, OS 64 bit Windows Pro 10.0.19042 20H2 version Pro Tools 2021.3.1 M-Audio AIR 192|6 Details: Lenovo 20U3000SSP ThinkPad L15 Gen 1 Lenovo R17ET26W (1.09 ) 01/11/2021 STMicroElectronics 2.0 2018 (24PCR 64Ses 8Obj) Intel ME (Unidad de Gestión : 14.0.39.1367 Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz (4C 8T 4.12GHz, 3.84GHz IMC, 4x 256kB L2, 6MB L3) Controlador de memoria : Lenovo Core10U (Cometlake-U 4C) ULV Host Bridge/DRAM Registers 101MHz, 8GB 1.35GHz 64-bit, Gráficos integrados Samsung M471A1K43DB1-CWE 8GB DDR4 1Rx8 PC4-25600SO DDR4-3200 (22-22-22-51 4-73-24-8) |
Re: Can't hear MIDI
You can simply create a aux track and inster the xpand plugin, select a preset and on the midi track the xpand will show up in its output selector. That's how we did it in the old days, then PT came with instrument tracks, which essentially is a aux track with a midi part. You could also just create a instrument track with a xpand, and simply drag your midi over to it.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Re: Can't hear MIDI
I try to keep it visually understandable.
One midi track One Audio track with VST instantiated Then you have to set up routing. The output of the midi points to the VST The input of the midi selects the keyboard already setup to use your midi interface in protools The input of the VST is set to none The output of the VST to whatever channel outputs for playback you choose. |
Re: Can't hear MIDI
There are no VSTs in Pro Tools. The rest is just jibbersish.
Re: Can't hear MIDI
Hi, welcome to the community.
In the current versions you would create Instrument Track that can hold MIDI and Audio. For the oldskool way there are a lot of tutorials, but you don't necessarily want to go there if you can choose Instrument Track.
Re: Can't hear MIDI
YouTube is your friend...search for instrument track
Microsoft Windows 11 Home 64-bit OEM DVD Avid OMNI PCIe Pro Tools Ultimate 2023.12 CPU: Intel Core i9-10980XE Motherboard: Gigabyte X299X AORUS MASTER E-ATX RAM: 64 GB Crucial Ballistix Sport LT DDR4 Screen card: MSI GeForce GTX 1660 VENTUS XS OC |
Re: Can't hear MIDI
Many thanks!
Re: Can't hear MIDI
But just to clarify some of the other posts There are 3 ways to use midi in Protools #1 (the newer one track simple method ) create and "instrument track" put the VI on it, start recording (or playing if dragging in midi from elsewhere) As others said an Instrument track includes a midi note field and also outputs audio # 2 Create a Midi track (for the midi notes) and an Audio track to output the sound ,,, put the VI on the audio track and route accordingly #3. For multi output VI Instruments ( like say 3 rd party drum VI's for one example ) Create an Instrument track put the VI on that,,, then create the appropriate number of Aux tracks (for the number of VI outputs) and route the specific individual outputs from the VI to the specific Aux tracks . I can post a screen shot if you like
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
Re: Can't hear MIDI
The rest is an accurate routing description unless you are a novice in midi. I personally don't like using instrument tracks. When the VI goes south i.e. stops working, they tend to be difficult to get working again. Each to his own. |
Midi Troubles, cannot hear MIDI track | EVaschon | Virtual Instruments | 4 | 07-29-2020 06:15 PM |
Can't monitor/hear midi by highlighting the midi track and playing the keyboard | jgagne1 | macOS | 4 | 01-18-2015 08:42 PM |
MIDI problem...can't change patch / hear MIDI | missmason | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-05-2006 09:43 PM |
Can't hear midi audio using plug-in midi instrumen | Adriano | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-18-2006 10:21 AM |
I can't hear the MIDI | jeronimo | Digidesign Hardware & Software | 2 | 12-16-2000 10:39 AM |
