Different grid settings in the same song?
Hi Everyone - I was wondering if it's possible to set the grid differently at various points in the same song? For instance I'm working on a song where the verses are swung, but the choruses are straight, so ideally I would have the chorus grid showing 16ths and the verses to show 8th note triplets. Can this be done as at the moment I'm changing the grid settings all the time when I'm working on the different sections?
Re: Different grid settings in the same song?
Yes.
Put the transport in conductor mode. Show the meter lane. Make a selection and manually enter the meter per section. In conductor mode, the midi info and grid will follow the meter changes.
bookerv12 |
Thank you - I thought there must be a way.
You can also use Ctrl+I to make a tempo-change - add a Beat Marker. Then the grid will adapt to your tempo-map.
Microsoft Windows 11 Home 64-bit OEM DVD Avid OMNI PCIe Pro Tools Ultimate 2023.12 CPU: Intel Core i9-10980XE Motherboard: Gigabyte X299X AORUS MASTER E-ATX RAM: 64 GB Crucial Ballistix Sport LT DDR4 Screen card: MSI GeForce GTX 1660 VENTUS XS OC |
Align song to Pro Tools Grid Video- Tab to Transients | djmichaelwenz | Tips & Tricks | 0 | 12-17-2014 10:32 AM |
conforming a song to a grid | chrisosaki | Pro Tools 10 | 9 | 04-10-2014 07:22 PM |
Slowing down grid at the end of a song | nwarren1981 | macOS | 1 | 11-03-2013 06:33 PM |
How to lock a grid onto a song | Stagefright13 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-27-2007 07:47 AM |
Song is drifting from tempo grid... Any suggestions? | exit | Pro Tools TDM Systems (Mac) | 6 | 06-04-2002 12:46 AM |
